Omega Help Area => Omega Electrical and Audio Help => Topic started by: autoelite on 09 April 2012, 20:55:29
Sorry if this has been asked before but here goes.
My front heated seats wont work at all. Checked fuse no 14 and all is fine but when I turn the switches on there is no lights at all. I have ordered some new switches to see if that fixes the problem but other than that is there any relays or any other areas that I should investigate.
on mine there is one in the fuse bay a relay can hear it click then the light comes on the switch.
Does sound like a power problem. Hopefully an easy fix :y
Failed seats should still lite up the switch on the dash.
No lights at all is there a relay read on here that mine has no relay but worth a check. Is it one of the relays in the fusebox or elsewhere looked online for its possible location and came up empty.
Check fuse #29
Will give #29 a go but the report from vauxhall says fuses seem okay and that it would require further diagnostic tests but all is worth checking
Ignore anything Vauxhall, or "Vauxhall trained mechanics" say, they are universally clueless :y
Should add, most other marques are almost as bad, but this is a Vauxhall site...
