Omega Help Area => Omega General Help => Topic started by: mick-1975 on 14 April 2012, 20:55:34
Title: a few problems again
Post by: mick-1975 on 14 April 2012, 20:55:34
evening all i have a 2.2 omega estate sport auto and im starting to have some problems with it
  1. i have the spanner light on and off .
  2. the engine light comes on
  3. and when im driving seems to come out of gear and revs up , if i leave it it goes in to limp mode . If i change it to manual then back into drive its ok for some time .
  4. and a oil leek coming from behind the power steering pump as i can see it drips down.
 i have a obd 2 so i can take the lights out when i have to
 codes are without it happening again are
1 0303 (cylinder 3 mis fire) had a coil pack
2 1751
3 1555 (brake something )
  and a few others but cant remember . Any help would be great as doing my head in otherwise might have to get rid of it as i need a car for work .
Title: Re: a few problems again
Post by: TheBoy on 15 April 2012, 09:46:39
A full list of codes would be helpful, but check ATF condition and level.
Post by: mick-1975 on 15 April 2012, 12:28:23
i thought it could be the gear selector . ill pop the codes up later today .
Post by: Steve B on 15 April 2012, 13:56:16
got exact same probs...its like a clutch pedal been pressed
Post by: mick-1975 on 15 April 2012, 17:42:08
thats right just like that revs up with no gear . Need to sort it
Post by: 2boxerdogs on 15 April 2012, 17:53:26
Had to buy some parts recently at my local VX stealership one of the senior mechanics who was outside the workshop remarked on the condition of my 2.2 auto estate & also told me to make sure I change the transmission fluid as most problems with the gearbox are rectified by this also change/clean the filter intend getting this done soon so maybe you could try this.
Post by: Steve B on 15 April 2012, 17:56:30
yep been told that too on here by many
