Omega Help Area => Omega General Help => Topic started by: grain.ben on 15 April 2012, 21:02:33
Title: Brake pads and air filters
Post by: grain.ben on 15 April 2012, 21:02:33
Hi guys, does anyone know off the top of your heads, the part number for the front brake pads on a 2.2? Calipers are Lucas and i already have the pad warning cable to go with the new pads.
Also, has anyone ever used a K&N replacement filter http://www.knfilters.co.uk/search/product.aspx?Prod=33-2734 , product code 33-2734, and if so are they any good? worth buying?, or just sticking with the original GM's?
Title: Re: Brake pads and air filters
Post by: Kevin Wood on 15 April 2012, 21:07:39
I'd stick to standard air filters. It's plenty large enough (especially for a 2.2. The same filter isn't restrictive on a 3.2).
K&N filters need regular oiling to keep the dust out, and the oil can contaminate the MAF sensor.
Post by: grain.ben on 15 April 2012, 21:10:03
ok ill keep clear of those then and use GM's  :y
Post by: Agemo on 15 April 2012, 21:33:16
Any part numbers you need, can be found here:-
http://opeloem.com/vauxhall/omega_1994_2003/
Also available on EPC, but I haven't even bothered to load it on this comp.
Post by: grain.ben on 16 April 2012, 13:12:27
cheers for that, will have a look  :y
