Chat Area => General Discussion Area => Topic started by: andyc on 02 May 2012, 17:00:30
Chancing my arm here
Just done an update in Suppliers section if anyone interested
Andy
Hmm. Trade Club branded oil? Looks interesting. Is there a fully synthetic option too?
Wonder how much it would cost me to get that delivered? I've finally run out of 10/40. Could do with some 20/50 semi as well
Hmmm, I'll start keeping my 5l bottles then, and decanting larger ones... ...I'll make a mess if I try pouring from a 20l can into an engine ;D
Just don't do it in the kitchen next to the stove
Do I look like a 'tard?
Actually, don't answer that one ;D
Although oil wouldn't give off enough vapour to catch easily...
re delivery. I'm back in bury in about a month so can pick up supplies then if anyone wants stuff back in the coventry area ( between coventry and birmingham airport that is)
drop me a PM to see if we can work something out
Yes it does.. Erm.. So I'm told. ::)
;D
Decanting is a problem on the bigger cans. Plus having a means of measuring how much is going in.
Although good heads up andyc :y
Kev: yes they do. Five Different grades of 5w30 and one of 5w40 for use on things like Merc, BMW, Ford, Renault etc
Andy
Thanks for heads up Andy :y
Done it before with 20L drum of Anti-freeze into 5L's quite tricky single handed really, due to weight & size and the small target. *insert dirty joke here*
With big metal drums, I've seen pumps are fitted on top, wonder if such an attachment could be found. Be quite useful especially with V6's needing 5.5L. Less mess as well having to keep pouring them into 5L
Yup: http://www.justoffbase.co.uk/Tool-Shop?search=drum+pump
Sealey make them, amongst others.. and I believe Andy is even a Sealey distributor ;)
Cheers :y
Some of them are not cheap :o
Wonder if Andy can recommend one?
all i use is a screw on barrel tape. Take the cap of and screw the tape cap back on, plastic ones i use are 3 or 4 quid the last time i got one
With mine i built a rack to take 3 drums on there side so i have oil at the top then antifreeze and the water and a space underneath for the old can any other oils
Andy
Andy
I've got a barrel tap somewhere. I wonder if it's the right thread?
Have look at the homebrew barrels.
Holds 20ltrs
Cap on the top and a tap at the bottom.
you could always give it a squart of gas to help it flow out the tap ;)
And pretty cheap
