Omega Help Area => Omega General Help => Topic started by: spurgindavid on 03 May 2012, 22:58:08
hello all, would just like to double check on my car as i have changed the dizzy and ht leads and want to make sure i have put the leads into the correct spark plugs :y
does anyone have a diagram or a picture of some sort that shows what number each cylinder is??
Many thanks -
(2.5 v6)
the diagram is actually embossed on the cam covers ;)
note also that the disspac doesn't run in the same order so double check the right pot is linked to the right disspac port. diss pac also numbered ;)
we havent got the cam cover though :'(
cam cover...
5...6
3...4
1...2
front.
(http://i1226.photobucket.com/albums/ee402/webbybear1/kjhb.png)
Shizzle. soz RB didnt see youd replied with a much easier method ::) ;D
beat you. :P
beat you. :P
Haven't you got a head gasket to be getin' on with?! :P ::) ;D ;D ;D ;D ;)
beat you. :P
all done mate, cam covers on in the morning, top end then start up.
beat you. :P
:y :y :y
beat you. :P
Haven't you got a head gasket to be getin' on with?(http://i266.photobucket.com/albums/ii269/theogrit/1sm106poke.gif) ! :P ::) ;D ;D ;D ;D ;)
;D
