Omega Help Area => Omega General Help => Topic started by: LFF64 on 10 May 2012, 17:05:11
Could someone check the price of rear pads for a 52 2.6 estate vented discs on Tc. hopefully the price I been given is wrong £51 +vat fronts were only£15+
Have a feeling vented rears are quite pricey! Sounds about right :(
Blimey thats expensive then :o
I thought all pads were the same :-\ :-\ :-\ :-\
Showing on Trade Club as £44.61.
Plus vat I assume.
Think vented rears on 2.6/3.2 are super expensive compared to 3.0/2.5 non vented which are only around a tenner
But why should the pad be any different? It's just a thicker disc! ??? ???
rear pads are the same but longer pins for vented,mine only cost me £5 last year but that was because the idiot posted them to a different address in the street and waited 2 weeks for them ;D
According to TC they are. :-\ Well, the 2.6 and 3.2 are. Didn't look at the others as it was irrelevant. :y
Just dug up the old thread I was thinking of, looks like the vented ones are not listed on TC, despite them being the same:
http://www.omegaowners.com/forum/index.php?topic=85246.15 (http://www.omegaowners.com/forum/index.php?topic=85246.15)
Pad set for Vented discs are not on the TC program and trade @ £51.31 + VAT. These pads do also come with the pad pins and springs.
Pads for the Solid discs which are on the trade club program and come out at £12.47 + VAT but do not come with any fittings
What you can do though is use the Solid pads on the Vented Caliper but either re-use the fitting kit or buy new springs and pins
The vented pins are £4.51 each + VAT and the springs are £3.45 each + VAT , so to use the solid pads with a new kit your looking at £37.41 + VAT
I will say that i've only heard of the Solid pads being fitted to the Vented calipers so i can not confirm if this will work so its at your owen risk
Oh and FYI the Vented pads are on back order with GM at the moment
Cheers
Andy
Great clarification as always Andy :y
I've always re-used the old pins :)
Hi AndyC,
What are 90541931 showing on TC just for clarification please, so I don't confuse the issue.
Edit. Doh they are shoes. :-[ :-[ They are listed under Rear Pads.
Cheers
Regards
Alan
At risk of agreeing with you ................ ::) ::) ::)
So do I!
I've replaced the anti-rattle spring that fits at the top recently & just bought them separately. :y :y
So do I!
Something is very, very wrong! ;D
Thanks everyone :y
Is that 4 x pins and 2 x springs and you wouldnt have part numbers would you please :y
Have a look at the condition of what you already have before you order them. The pin will be OK, it's just the spring that might be broken or ready to break, and you could manage without it till you then order it. :y
Do you have to have vented discs?
If not then non vented at price AndyC quoted and springs/pins set for £6 at eurocarparts :)
HTH
HTH
If you already have vented discs then YES you do. Solid discs would physically fit in vented discs calipers, but the vented discs calipers are wider to allow thicker vented discs. All would initially appear OK until the pads wear down a bit, then the rear(?) piston would pop out of the caliper leaking brake fluid all over the place while giving you the feeling of WTF is my brake pedal resting on the carpet? :o :o :o
Replace vented discs with vented discs unless you want to replace the caliper too! :y
HTH
That makes perfect sense. Thanks Andy :y and vented is referring to the vents all the way around the top of the disc i trust (stupid Q but worth checking ::))
So if the pads are exactly the same and the only difference is the longer pins..... surely the OP could buy the £15 pads and seperately buy the longer pins and new springs from eurocarparts as i remember the guy on the phone said he had both in stock. :y
Yes. A vented disc is as though you had two slim discs 'stuck' together with a vent in between ie there's a gap between them.
yes.
Sorry me again has someone got the part number gor the solid pads on tc i popped in to Skurries in kidlington and he was quoting me £61 :o
93169001. I have a set on the shelf if you get stuck
Andy
Thanks Andy :y
