Omega Help Area => Omega General Help => Topic started by: flymofred on 24 May 2012, 16:22:25
Title: Should've checked first
Post by: flymofred on 24 May 2012, 16:22:25
I've shut the bonnet and left a  small plastic cap in the channel on the wing top. The bonnet closed ok but is high on the side where the cap is. As a result I can't unlatch the bonnet or get to the cap. The operation of the bonnet lever was marginal before and was on my list to fix. So now all the lever movement is taken up by the cable stretching. Any ideas please.
martinH
Title: Re: Should've checked first
Post by: martin42 on 24 May 2012, 16:27:19
get some1 to pull release cable and you push down on the bonnet  :y
Post by: tgm147 on 24 May 2012, 16:27:37
Pull the cable and 'bounce' the bonnet. You'll need two people but be very careful doing it!
Post by: flymofred on 24 May 2012, 16:51:17
Excellent service as always. Thanks for your advice I'll give a go
Cheers
martinH
Post by: Steve B on 24 May 2012, 17:38:27
worked for me too.... :y
Post by: flymofred on 24 May 2012, 21:05:04
Yes that is a result. And I have also adjusted the bonnet release cable .
Thanks for the help.
martinH
