Omega Help Area => Omega General Help => Topic started by: Lampynoiseboy on 14 June 2012, 11:36:50
Title: Engine trouble
Post by: Lampynoiseboy on 14 June 2012, 11:36:50
Hi All
My mig has issues. Last week or so been a bit slow to start, and last few days there's been a bit of bunny hopping. Rev jumps between 1 & 2.5k, no power (or intermittant), stalled twice. Has only happened 5 times in a few days b ut don't want it to get any worse!
Friend has a snap-on Solus reader, returns the following codes:
0172 fuel trim bank 1 malfunction
0173 fuel trim bank 2 malfunction
Any ideas?
Title: Re: Engine trouble
Post by: Marks DTM Calib on 14 June 2012, 12:10:43
Check the idle air flow reading when warm, my betting is that its either low or high.
Post by: Lampynoiseboy on 14 June 2012, 12:37:50
He did that, said it was normal
Post by: Darth Loo-knee on 14 June 2012, 12:48:14
Get someone who knows what he is doing mate with either a tech 2 or similar to check it. I had the exact same codes I promise you. A MAF sensor cured it.
The Master is very rarely wrong :y
Post by: Lampynoiseboy on 14 June 2012, 12:50:23
Haha, mind ur head!   ;)
Cheers mate
Post by: Darth Loo-knee on 14 June 2012, 12:52:57
Cheers mate
There is only one Master. That happens to Mark DTM  :y
Oh and your welcome :-*
Post by: Lampynoiseboy on 14 June 2012, 12:56:26
Ah, didn't realise you were both refering to the same thing!
And how rather much???????  :o :o
Post by: Darth Loo-knee on 14 June 2012, 13:16:27
How much. I assume you mean for a MAF Sensor? Vauxhall about £140. Cavectra where I will be getting mine £90 ish..
Although one of the breakers maybe able to help. Typical I had one here up until a few weeks ago :-\
Post by: Lampynoiseboy on 14 June 2012, 13:17:03
Rather?? Since when did the s/w recognise the irish f-word!
Anyhoo, can get one new for £140 + vat
Anyone beat that? 2nd hand maybe?
Post by: Lampynoiseboy on 14 June 2012, 13:17:54
Cross post!
Is that a genuine from cav?
Post by: Darth Loo-knee on 14 June 2012, 13:18:41
Cavectra is in Greys Essex so maybe not far from you
Post by: Darth Loo-knee on 14 June 2012, 13:21:00
Cross post!
Yes. You have to remember Vauxhall don't make their own parts. The genuine MAF Sensor would be a Bosch. The one you buy from Cavectra in Grey will also be Bosch and identical :y
Post by: Darth Loo-knee on 14 June 2012, 13:28:55
Here you go Lampy ;D
Cavectra's phone number
01375 391305
Post by: Darth Loo-knee on 14 June 2012, 13:32:53
I would though like I said earlier get someone with a tech 2 or similar who knows what they are looking at to check your car before buying anything.
What "The Master" which is Mark DTM himself says about the MAF is exactly what mine was doing, also I got the exact same codes as you have posted.
Post by: Lampynoiseboy on 14 June 2012, 13:36:06
Thanks mate
Unfortunatley I don't think anyone with a tech 2 is close
Post by: Darth Loo-knee on 14 June 2012, 15:56:13
I was dowm your way at the weekend too :(
Post by: Lampynoiseboy on 14 June 2012, 17:27:15
It was working at the weekend! *facepalm*
Post by: Lampynoiseboy on 17 June 2012, 16:46:47
Well
Having had my guy read the codes as stated earlier, forgot to mention he did pull some bits off & put them back again. yes, I know that's vague, but I know less than nothing about engines. His first suggestion was also MAFF sensor, but he wasn't convinced hence the post on here.
However, since then it's been perfect, so guessing it was just loose or had shite in it?
Post by: Lampynoiseboy on 19 June 2012, 18:27:40
And he does normally know what's what straight away, was just unwilling to spend £140 of my money without being sure!
Fair I thought.... :y
Post by: Lampynoiseboy on 13 July 2012, 19:18:25
Well
New maf sensor today thank to cavectra centre......still same issues
Any thoughts?
Post by: Lampynoiseboy on 06 August 2012, 09:59:39
Still playing silly buggers, but seems to be only when under a 1/4 tank of fuel, keeping it over that makes it behave.
I'm thinking fuel pump, any opinions for/against?
Post by: a2reed on 06 August 2012, 10:11:20
C0uld be dispack ... that would give intermittent performance similar to MAf sensor going ... I had the same on mine ...codes were saying MAF but it turned out to be dispack and by the time I got it out you could clearly see it was buggered... so if you have a spare 2 hours and don't want to waste any more dosh you could take out the dispack and check it
although the evidence with the extra fuel in the tank points away from that ... Blocked fuel filter/ fuel pump ???...I would still check the dispack
Post by: albitz on 06 August 2012, 10:51:30
3.2 doesnt have dispack,has a coil pack per bank.worth doing the usual visual checks of coil packs,plug wells etc. Depending on service history,may be worth changing plugs,fuel filter etc.
Ideally a tech2 session to save on guesswork. Did I give you a number for a bloke local to you ?
