		Omega Help Area => Omega General Help => Topic started by: Bojan on 25 June 2012, 19:57:30
				Hello all!
 I know it has been covered in many posts, but here I go....
 Apparently, the coilpack on my 3.0 V6 died out today. Car was running perfectly yesterday, and today it runs like a VW bettle  >:( >:(
 Tested it by pulling out the ignition leads, and it seems like cylinders 3 and 6 are not working.
 I couldn't pull the leads all the way out, only 1-2 cm, and when I do so, I get tick noise (presumably when spark 'jumps' from lead to spark or surrounding metal) on cylinders 1,2,4 and 5. On 3 and 6, there is no such sound.
 I'm almost 100% sure that the coilpack has failed, but wanted to double check before buying a new one (BTW. new one here is over 300€).ž
 Thanks!
				I had a similar problem last year. The only way to be sure is to actually take the coil pack out of the car. I only examined mine by torchlight and couldn't see the damage so went about replacing spark leads, plugs only for the problem to persist.
 I think you will have to remove it to find out what type you have before you can order a replacement. You will need the part number.
 I replaced mine with a used one from a breaker.
				Only when you take it out and it looks like this you know its for the bin  :y
 (http://i219.photobucket.com/albums/cc41/milleblack/Photo0033.jpg)
 omg that looks broke ;D ;D ;D ;D
 in some places it would be classed as art. ::)
				Take care with only a visual check - when mine went, visually it looked perfectly ok but a replacement cured my misfire.
				I've managed to pull out the coilpack. It's a 0221503010 (square connector).
 It seemed visually OK at a first sight, but then I noticed a small crack between cylinder 3 and cylinder 6 plugs -> I suppose that this is the reason that for failure.
 I will post a picture in a few hours.
 Anyways, found several e-bay stores in germany, offering original BOSCH coilpack for around 130€.
				Just replaced the coil (installed new original BOSCH unit), and it still doesn't fire on cylinder 3 and 6!
 What could it be?
 The cables are connected correctly....
 help  :'( :'(
 What could it be?
 help  :'( :'(
 what are your spark plugs like?
				I'm sure that they are good. I've replaced them 15000km ago.
 Also, I'm still not getting a spark on cylinders 3 and 6. As said earlier, when I pull the cable lead of the spark plug, there is a knocking sound, on all cylinders except 3 and 6.
 Perhaps the coilpack isn't getting the correct signal -> only gets the signal to 'fire' the 1-4 and 2-5 coils?
 PS. I'm not getting any codes (did the paperclip test).
				Move the HT leads, see if the miss-fire changes :y
				Check your plugs again  ;)
 I had a HT problem earlier this year.
 Knackerd lead had burnt out the centre electrode on a plug  ;)
				Both plugs and plug leads are quite new.
 Also, I mounted a spare lead and plug, and it doesn't give a spark on 3 and 6, either.
 So, definitely, coilpack is't giving a spark on 3 and 6.
 After checking the coilpack cable (this is a signal cable, with 4 wires), I have seen the following:
 - the coilpack connector has been tampered with - it is tapped all over
 - there is one wire that is coming out the coilpack connector loom (its connected to just one of the wires in to loom), and it goes to LPG installation -> been told that this is used for turning on the LPG at certain revs
 There is one thing that I'm very afraid now -> could there be any kind of short-circuit or similar in this loom, which could cause a brand new coilpack to burnout instantly???
				The car is finally fixed  :D :D
 It turned out that ECU unit was bronen, so they replaced the faulty componenet, and the car is working fine now.
 So, buying a new coilpack was a mistake, but, hey, at least I don't have to fear of coilpack failiure for some time ;)
				Very unusual to see those Motronic 2.8.x ECUs fail in any way :o
				I know. I was amazed with this, too.
 Hope all will be well now.
