Chat Area => General Discussion Area => Topic started by: Essex_Andy on 28 October 2006, 21:28:35
Where I bought the new n/s headlamp today they had a set of 3.0 cams for £100..........guess what is sitting next to the 3.0 polished and modded throttle body, new cam cover gaskets and o-rings and camshaft seals?!?!?!?!??!?!!?
Next payday or possibly in the new year I'm going to get a cam belt kit and FSE boost valve. If possible looking for helpers to get this project finished.
Breakfast, lunch (and supper if need be) stellas and JD on me
I would like to help Andy but im useless with spanners and I live miles away. Sorry
Your only interested because the word Stella appeared :D
Stella, JD and breakfast :y
[quote ]
Stella, JD and breakfast :y[/quote]
The building blocks for a great day :)
Correct ;)
How about this then EP
Plan A :- Get Mark to do some cams, get Robin Hood to make a DVD of it. Buy DVD. Tell Mrs EP your going to Santo Podi, pick me up on way( although you would have to sort out that dodgy aeriel first) drive down to Essex, help Andy, Hey Presto....... Stella JD and Breakfast :y
Plan B :- Stop Dreaming ::)
From the measurements I did today......the 3.0 and 2.5 throttle bodies have the same size butteflys....
It cost me a whopping £30 and I took my little polishing mops to various bits...not too smooth as I believe a bit of turbulence is good. Not sure if I was having my leg pulled but the 3.0 item is a slightly larger bore? ? ?
I will start packing my tool kit (hammer and screwdriver) :y
Take it you've borrowed the screwdriver ::)
I got it using my Greenshield stamps ;D
Reminds me of a foreman fitter where I used to work.
He had a toolkit that was arranged in weights from toffie to sledge and a screwdriver made from a bit of power hacksaw blade ground down and wrapped in insulation tape for a handle.
I was told this guy used to work on Spitfires during the war, "Who for I asked the bloody Luftwaffe?"
;D ;D ;D
FSE valve will be an absolute waste of money, if you are desperate for extra pressure get a standard 3.8 regulator from a saab v6 or a 2.6omega etc, it should be cheaper and straight forward to fit. Personally i wouldn't bother though, there is no much gain.
But I thought butterfies die within 2 weeks :o ;D ;D
Andy - I might be able to help ... when's your next payday then?
I've only just started and cant remember...how sad is that!!!!!
I'm bargaining at the end of the month.
I'm away on training until mid december from tomorrow...so I'm planning to to do it after the New Year.
After my night shifts I get 7 'rest days'. Thats probably when...and until I get assigned a shift I'm have no idea when my nights will be?
Not much help really!!! Sorry
OK well let me know nearer the time when you do know!
Should have my locking kit available then too.
Cheers fella will do :)
