Omega Help Area => Omega Electrical and Audio Help => Topic started by: Greg2041 on 08 July 2012, 15:01:11
Title: My Car won't start. No feed to the petrol pump. Help!
Post by: Greg2041 on 08 July 2012, 15:01:11
The AA sub-contractor has given up.  Any ideas?
My car is a 3 litre V6.
Thank you
Greg
Title: Re: My Car won't start. No feed to the petrol pump. Help!
Post by: tunnie on 08 July 2012, 15:08:21
What has lead to the diagnosis of fuel pump?
Have you read the codes?
Post by: RobG on 08 July 2012, 15:33:51
Sounds like crank sensor mate. Duff sensor = no fuel delivery :)
Post by: albitz on 08 July 2012, 15:48:20
Yep, probably crank sensor.Lookin maintenance guides for paperclip test and expect to find a code 19. Genuine sensor only. :y
Post by: Greg2041 on 08 July 2012, 16:38:46
Thanks guys.  What would I do without you.  :y  Fault codes.  Would the AA know about them - or their sub-contractor?
If it is a crank sensor, dare I ask cost of part and labour.  Be gentle with me!
Greg
Post by: RobG on 08 July 2012, 16:44:19
Greg
Get them with a paperclip http://www.omegaowners.com/forum/index.php?topic=90581.0
Post by: Greg2041 on 08 July 2012, 16:49:43
I'll check when it stops pelting down with rain.  Are Crank sensors dear or difficult to fit? :-\
Post by: albitz on 08 July 2012, 17:18:30
I believe the sensor is around £70. Takes 5 minutes (and one torx socket) to change.should be info in the guides. :y
Post by: Andy H on 08 July 2012, 17:20:08
Have a read of the maintenance guide V6 Crank Sensor Replacement (http://www.omegaowners.com/forum/index.php?topic=90540.0)
Post by: Greg2041 on 08 July 2012, 17:48:11
Thanks Peeps and for the link too.  I'll keep you informed.  ;)
Post by: Greg2041 on 12 July 2012, 13:31:24
What a pain.  Yup, a faulty crankshaft sensor and now it starts but it takes ages and ages to do so and there is a loud click every now and again when starting.  Now it won't start again.
Any more ideas?  :'(
HELP!
Post by: tunnie on 12 July 2012, 14:17:30
You have found the fault. Crank sensor, it needs replacing. Geniune sensor only  :y
Post by: Dave DND on 12 July 2012, 16:00:07
Sorry, needed saying again
Geniune sensor only
 :-X
Post by: Greg2041 on 12 July 2012, 19:16:23
Thank you peeps.  Anyone else want to say genuine sensor?  :o
Post by: Dave DND on 12 July 2012, 19:17:42
Only if you ended up fitting an el-cheapo pattern one   ::) :-X
Post by: Greg2041 on 12 July 2012, 19:32:43
'Tis indeed a mystery.  The garage assured me that it was a genuine part but I guess even they can become faulty - Unless it is a wire somewhere?
Post by: furion on 12 July 2012, 23:14:19
Can you try and disconect the MAF,and then start it?
Post by: Greg2041 on 06 August 2012, 15:32:49
Yup, a change in crankshaft sensor again sorted the problem.  This site is the best!  :y
