		Chat Area => General Car Chat => Topic started by: zirk on 05 August 2012, 13:24:20
				Dangle Bloody Berries, cant believe Ive just done that!
Remind me please, easiest way to get in the Boot, without a spare key!
				Through the rear seats ;)
Cars deadlocked LD, really dont want to do a window, because Im not convinced I can get to the Manual pull with a LPG tank in the way?, also not sure if the release button works with the car locked up?
How big's the tank? As for deadlocked... There is a solution but I don't know it and it's not something that should be shared (publicly) online ;) If you get really stuck I have a set of Jigglers and might be able to get down to you during the week :-\
				Thanks LD, on plan E at the moment, thinking out load, I can get the Bonnet up, assuming the Boot Release works with the Car locked, Im guessing the switch wires, either as a pair (or one goes to ground or 12v) goes to the ECU, so can someone tell me the wire colours or ECU pin out maybe? or PM me the info.
Thanks
How big's the tank?
Not sure, guessing 80 or 90, but around £62 to fill from empty.
How big's the tank?
Ahh... That makes it too big to get past. The 80L tanks we recommend do (we think) leave enough room to get the release (just) :-\
With access to the engine bay, even if you just fire the central locking it's a start ;)
How big's the tank?
May need a bit more info on that ;)
				JamesV6CDX knows how to access the boot
http://www.omegaowners.com/forum/index.php?topic=103625.0
Thanks
ECU is in cabin, so no help ;)
If deadlocked, I'm guessing window :(
Stupid inferior facelift design.
I suspect though, there are loads of cars out there that you can easily do the same thing with. Both SWMBO's Smart & my 'new' R Class will both open their boot/tailgate without unlocking the rest of the car, you then put the key down while you load/unload your car, shut the boot and then ask on a forum how to get into the car when your only key is locked inside!  ::) ;D ;D ;D
Thanks Rob, James is off line at the mo, plus I need the Car for tomorrow if you know what I mean.
Thanks
Thanks for that, bugger, off to get another Saloon so I can have a play, will be back in 15.
I rest my case.
Makes the superior PFL design so much better, if less profitable for the dealers
I rest my case.
Just make sure your 'new' car comes with two keys ........ like we didn't with her Smart - £190 for the privilege a new one!  >:( >:(
So weve heard. :P ;D ;D
				Pfl stops nobody walking up to the unlocked boot and helping themselves while your in it at the lights. Which can't happen in the superior face lift. :)
				Zirk,you have PM. ;)
You just put the key in the lock & turn it ........  ;) vertical = opens & closes with central locking, horizontal - always locked  ::) ::)
I rest my case.
First thing I do is sort out a spare key, on any car.  Which reminds me, I need to order a new spare for the bike. Again.
Even Golden Nugget had a spare key sorted out for it, even though I only had it about 6 weeks ::)
First thing I do is sort out a spare key, on any car.   ......
hence the £190 for another Smart key, SWMBO can never find the same key twice!  ::) ::)
				Just had a quick butchers at another Saloon, hmmm, plan F coming up. ;)
Thanks Albs, going to try Plan F first.
:y :y :y :y
Boot now open, said Key in hand, no broken glass!!
and so easy, too easy in fact!!!
The way the Olympic Red Lights are set at the moment, I reckon I can now get into a FL Boot in that time.
 :D
:y :y :y :y
How?
				Zirk,
Trying to PM you, but inbox full.
Zirk,
Sorted.
:y :y :y :y
How?
Popped the Boot Rob.  ;)
				PM sent
