Chat Area => General Discussion Area => Topic started by: Dishevelled Den on 08 August 2012, 20:01:44
Title: A
Post by: Dishevelled Den on 08 August 2012, 20:01:44
......quick question. (That'll pish Turk right off ;D)
I've taken to using me laptop more often now and, while I sit here with it getting lovely and warm on the nether regions, it's struck me that I run it all the time from the mains but have left the battery in situ - is this a bad thing and should I remove the battery?
Thanking you all in anticipation.
Den the Shami lover.
Title: Re: A
Post by: RobG on 08 August 2012, 20:11:52
Yep.
http://thisweekinbatteries.blogspot.co.uk/2010/02/pull-plug-your-battery-will-thank-you.html
Title: Re: A
Post by: feeutfo on 08 August 2012, 20:28:30
Heat no good for your knackers either. I hate lap tops, purely because of the heat they put out. There will be less heat if not on charge though, iirc. :-\
Title: Re: A
Post by: TheBoy on 08 August 2012, 20:36:34
Modern batteries don't like to be discharged, they prefer to be kept reasonably topped up.
Title: Re: A
Post by: Dishevelled Den on 08 August 2012, 21:15:08
Thank you all :-* :y
Plug now pulled and knackers comfortably warm - but that may be the result of looking my Shami desktop backround picture. :P :P :-*
Title: Re: A
Post by: Turk on 08 August 2012, 21:38:58
Excellent !  Deep joy !!  I'm so glad it's sorted.  Now the plug has been pulled, you can STICK IT UP YER  :-X :-X :-X :-X.    :y
Title: Re: A
Post by: PhilRich on 08 August 2012, 21:59:34
^^^ ;D ;D ;D ;D ;D :y^^^^
Title: Re: A
Post by: Dishevelled Den on 08 August 2012, 22:48:59
 ;D ;D ;D ;D Splendid  ;D ;D ;D :-*
Title: Re: A
Post by: aaronjb on 08 August 2012, 23:28:35
I saw the title and thought this was a thread just for me..
But alas, no. T'was a thread just to annoy Turk.  :'(
 ;D
Title: Re: A
Post by: Rods2 on 09 August 2012, 02:59:08
so you are now having a controlled discharge.........  ::) ::) ::) ::)
........of your laptop battery.  ;D ;D ;D ;D
Title: Re: A
Post by: mantahatch on 09 August 2012, 07:45:18
I am really dissapointed, i thought this was going to be athread about "A" http://www.youtube.com/watch?v=a1z9_TGX7-E
Good band for the time.
Title: Re: A
Post by: Plomien on 09 August 2012, 07:48:19
If you are worried about cooked knackers then get a cooler, but make sure you have a fan guard if you are looking at your Shami picts Den
Title: Re: A
Post by: aaronjb on 09 August 2012, 09:59:45
Pretty sure Kerrang still play that .. mind, last time I watched their channel their playlist didn't seem to have changed in 10 years ;D
Title: Re: A
Post by: mantahatch on 09 August 2012, 10:40:18
Hey, if it aint broken then dont fix it  :y Seriously though you are probably right.
