Chat Area => General Car Chat => Topic started by: sarah1969 on 14 August 2012, 20:13:53
Title: Back windows wont open, front ones do
Post by: sarah1969 on 14 August 2012, 20:13:53
Hi All
I brought my omega four weeks ago and already i have replaced the right arm and bushes it still needs pads and new tyres. Now my back windows wont open but my front ones do. Ive checked the fuses and thats ok can anyone guide me further. Also ive been told that the car needs a gasket between the engine and down pipe. When the engine is cold the EML light flashes on and off and i loose some of the power but once the engine has warmed up everything seems fine. Do you think this is the gasket? Its a lovely car and i really want to fix these problems its a 2.5 V6 GLS S reg.
Hope someone can help.
Best wishes
Sarah
 :) 8) ::) :D
Title: Re: Back windows wont open, front ones do
Post by: Andy B on 14 August 2012, 20:17:28
Which switches are  you using? The rear door switches can be turned off from the front green/red switch by the front set of switches.  :y
Do the paperclip test & see what code (if any) you get.  :y
Title: Back windows wont open, but front ones do
Post by: sarah1969 on 14 August 2012, 20:22:08
Hi All
I have just bought an omega 2.5 V6 GLS S reg and already i have had to replace the right arm and bush. It still needs pads and new tyres. Now the back windows wont open ive checked the fuses there ok any ideas? I love this car and really want to stick with it and fix the problems. Also when the engine is cold i loose some power and the EML light flicks on and off i have been told i need a gasket from the engine to the down pipe could this be the reason the car looses power when its cold, once its warm its fine. I really hope some kind person can advice.
Best wishes
Sarah
 :) :D ;D :-*
Title: Re: Back windows wont open, but front ones do
Post by: Andy B on 14 August 2012, 20:28:56
You only need to post in one section ................. we'll see it!  ;) ;)
Post by: dbug on 14 August 2012, 20:54:23
Paperclip test will ony show engine faults mate  ???
Post by: dbug on 14 August 2012, 20:56:15
You've posted in the right section Sarah - ignore him above ^^^  ;)
Sure you've not got the "Child safety" switched on?
Check Fuse 15 - although if fronts work should be ok
Post by: tidla on 14 August 2012, 20:58:30
I don't think Andy was referring to getting paper clip info for the repair of the windows. ;D
Post by: dbug on 14 August 2012, 21:08:11
OK - but if its dodgy exhaust gaskets this wont show up either  ::)
Post by: Turk on 14 August 2012, 21:55:30
As for the EML question, 'How to Paperclip test' and links to what the code indicate here:
Post by: Andy B on 14 August 2012, 22:41:03
http://www.omegaowners.com/forum/index.php?topic=106253.msg1329438#msg1329438
http://www.omegaowners.com/forum/index.php?topic=106251.msg1329433#msg1329433
http://www.omegaowners.com/forum/index.php?topic=106250.msg1329419#msg1329419
Bound to be in the right section if you post in enough of them ......  ::) ::) ::)
Post by: Andy B on 14 August 2012, 22:44:45
Might give a clue to the flashing EML light though ..............  :P :P
Post by: Steve B on 14 August 2012, 22:50:26
agree with andy b....read the rules they are there for us all...............post in the correct place and stop  chucking it all over the forum
Post by: tidla on 14 August 2012, 22:53:57
 ;D ;D
Post by: Turk on 14 August 2012, 23:52:44
Alright folks, give it a rest !   That's no way to welcome a new member.  >:(
Post by: dbug on 15 August 2012, 00:05:44
Agreed, hence my comment ;)
Post by: Andy B on 15 August 2012, 00:08:10
I'd already replied elsewhere with my suggestions ..............  ::) ::)
Post by: dbug on 15 August 2012, 00:10:17
So have I mate - thats not the way to treat a new lady member  ;)
Post by: sarah1969 on 15 August 2012, 06:55:43
hi All
Thank you for your help. Im sorry i posted in a few places am new and wasnt sure of where to post
Sorry again if ive upset anyone that wasnt my intention
Best wishes
Sarah :-[
Post by: Jimbob on 15 August 2012, 08:13:04
Right, merged the 2 topics to save any confusion.
As stated, use the links in my signature to do the paperclip test for engine codes....should shed some light on that issue.
Did the 98 GLS have electric windows from new?  have they ever worked for you, or just stopped working?
I presume youve checked using the switch on the door, and the one by the gear selector?
