Omega Help Area => Omega General Help => Topic started by: nordic on 17 August 2012, 15:00:08
Title: Radiator Fans Not Working
Post by: nordic on 17 August 2012, 15:00:08
Hi,
Sadly, my twin radiator fans have suddenly stopped working! :'(
Where should I look to solve the problem? :-\
Cheers
Andy
Title: Re: Radiator Fans Not Working
Post by: Entwood on 17 August 2012, 15:02:43
fuses in the triangular box by the battery IIRC ... green ones... think there are 2 :)
check here ... depending on which engine you have ....
http://www.omegaowners.com/forum/index.php?topic=90458.0
Post by: Turk on 17 August 2012, 22:16:54
Pretty sure one of them only runs with A/C on.
Post by: nordic on 18 August 2012, 12:45:34
Thanks for the help so far :y
Checked the fuses and they are all ok.
Where else should I explore? :-\
(I have a 2001 3.0 V6 auto)
Thanks
Andy
Post by: RobG on 18 August 2012, 12:50:54
Relays
http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
Post by: nordic on 18 August 2012, 13:23:32
Hi - Tested relays and they are all fine.
Any more thoughts? :-\
Andy
Post by: nordic on 29 April 2013, 14:45:14
It was the electricity supply to the relays. Got there in the end!
Many thanks to all that helped.
Cheers :y
Post by: robson on 29 April 2013, 17:41:10
If the fuses and relay was ok what caused the problem
Post by: Webby the Bear on 29 April 2013, 17:56:54
Well done Nordic... did you find that by doing a multimeter test on the connector (going to the fan) and hooking it up to a decent ground to see if you have battery voltage? :)
also did you then search for a short?
