Omega Help Area => Omega General Help => Topic started by: duke101 on 19 August 2012, 12:13:41
Title: ABS ECU UNIT COMPATABILITY
Post by: duke101 on 19 August 2012, 12:13:41
I have a mini facelift 2000 V6 Automatic Omega with cruise control and,I suspect, a faulty ABS unit (rev counter mostly at maximum and ABS light always on) marked 0 265 220 644 (not sure if its the original or not)...I am breaking a year 1999 pre facelift V6 automatic , no cruise control, with a good ABS unit marked 0 265 220 427..anyone know if they are interchangeable please?
Title: Re: ABS ECU UNIT COMPATABILITY
Post by: tunnie on 19 August 2012, 12:26:16
Same engine?
Post by: duke101 on 19 August 2012, 12:33:57
Yes same engine in both cars ...  both 2.5 V6...theres only a few months difference in age of the cars but ones pre facelift,others mini facelift.
Post by: tunnie on 19 August 2012, 12:39:39
Both Autos too? Think as long as they are same engine/transmission should be ok.  :-\
Post by: RobG on 19 August 2012, 12:44:31
Yep
Post by: duke101 on 19 August 2012, 12:45:46
Yes both auto....ill give it a try then thanks.
Post by: TheBoy on 19 August 2012, 17:27:10
As long as similar engine/gearbox, AND both come from MFL or FL....
Post by: Andy H on 19 August 2012, 19:36:01
Did you mean to write rev counter? AFAIK there is no connection between the ABS and the rev counter.
Typical symptoms of ABS ECU failure are that the speedometer goes to zero & both ABS and TC warning lights come on.
Before spending too much time looking at specific components I would check the battery & charging circuits and also try removing and reinserting the instrument console to check that it is plugged in properly.
Have a read of Battery Charging and Starting Diagnosis (http://www.omegaowners.com/forum/index.php?topic=90619.0)
Post by: dbug on 19 August 2012, 20:18:39
Rev counter at maximum=heavy right foot ;)
As said failing ABS ECU puts abs & tc lights on, problems with speedo not working and loss of some power assistance.  Not connected to rev counter at all.
Post by: duke101 on 19 August 2012, 22:50:51
Just to update this, although the cars not been on the road yet as i still have the brakes to bleed i can confirm that changing the ABS unit has cured the rev counter (yes the rev counter ) and the tc light now switches on and off....before change the rev counter mostly stayed at 7000rpm, the speedo worked, and the traction control light was permanently on!
Post by: duke101 on 20 August 2012, 00:04:26
Just seen The Boys post, as stated the cars were a pre FL and a MFL...but is there a problem because of that?
