Omega Help Area => Omega General Help => Topic started by: chelskifl on 31 August 2012, 13:34:29
Title: MAF Fitted
Post by: chelskifl on 31 August 2012, 13:34:29
Omega 3.0 elite estate 1997  car was not starting , well would with a lot of effort, so i odb2 came up low voltage MAF, so i purchased a new MAF fitted. cleared error codes runs ok. the problem i have before the problem MAF i could turn the key no throttle startup no problem, no i need to apply a little throttle to start, also if engine idling, and i depress the throttle quickly ,, there is a slight delay before pick like dead spot
if i depress normally seems ok, i have ordered a new air filter to see if its that. i have been told it takes 20 miles for the ecu to setup after MAF fitting .... is that True?
Also looking at the back of the engine top under scuttle there is a Rubber Hose about an inch across not connected no clip on it can not see where it goes looks like it goes down to the sump could it be a breather, please advise
Title: Re: MAF Fitted
Post by: tigers_gonads on 31 August 2012, 13:38:33
You will get more help with this if you post it in Omega General Help  :y
The big pipe sounds like its the one that goes from the back of the plenum down to the breather box on the back (drivers side) of the engine
Post by: Varche on 31 August 2012, 14:14:08
Hi, your profile doesn't say what car and auto /manual etc. Assuming it is an auto the tube will be the gearbox breather pipe. It doesn't coonect to anything at the back of the engine compartment.
Has the ICV (idle control valve been cleaned) - worth doing anyway and an easy enough job.
Post by: chelskifl on 31 August 2012, 14:28:00
yes auto sorry... yes i have cleaned icv (carb cleaner) and a couple of drops of oil
Post by: chelskifl on 31 August 2012, 14:35:38
got a couple of clips missing on the air filter box, dont know were to get those from might adapt couple of tie raps.. seems to be sealed ok though,, it's just puzzling when i throttle really quick it's lick a slight lag at the start. if i do it steady ok... i have a new air filter on order maybe that will cure the problem any ideas would be helpfull and thanks about the pipe breather auto.. its just when you have had the car for such a long time you know how she rock and rolls.....
Post by: tigers_gonads on 31 August 2012, 14:41:09
Is there any slack in the throttle cable at the engine end ?
Post by: chelskifl on 31 August 2012, 15:08:03
i will check nice one... :o
Post by: chelskifl on 31 August 2012, 15:48:09
no cable ok , if i use throttle from engine end .. same fault .. it's like its gasping for fuel if that makes sense  it's only a moment before pick up..  if i increase the revs ever so slightly better  :( just thinking i have some weight in the back at the moment would that effect throttle response,,,,, grabbing at straws now arn't i
Post by: noel on 31 August 2012, 22:02:22
have you tried cleaning the throttle body ??  just thinking out loud  ;)
Post by: dbug on 01 September 2012, 01:14:36
Rear multiram working?
Post by: chelskifl on 01 September 2012, 11:30:27
 ::) will have a look later... some times it's best to leave it have a cuppa clear your mind :D
Post by: chelskifl on 06 September 2012, 17:09:15
 :y ok MAF's Law..... Don't Buy Cheap Mafs on Ebay..... Crap,, Bought a Bosch One Fitted It Now Runs Like A Dream  8)
Post by: chelskifl on 06 September 2012, 17:10:18
CHEAP MAF VS BOSCH MAF ......... BOSCH WINS OUTRIGHT :y
