Omega Help Area => Omega Electrical and Audio Help => Topic started by: Bob G on 07 September 2012, 12:47:09
Got the leather seats in today apart from Passengers, one bloody torx seized and rounded off, apart from that a nice easy job, thanks to Marksdtm for the wiring of the drivers seat works very well. Have left the heated seat bit till later. What is the box behind the drivers kick panel as it looks as if most of the front heated seat wires seem to end up there after coming from the switch.
I can only think alarm/locking ECU, and higher up, autobox ecu?
GLS so no alarm, has to large multi plugs goin in
Non GLS have Alarm ECU. GLS have a similar ECU in the same place for Central Locking (Alarm ECU on other models provides the central locking function)
Ah so then it could wll be the c/locking ecu then
But seats wouldn't wire into that... ...or at least I can't think why they would
C/L alarm ECU (one with label) ;)
(http://i190.photobucket.com/albums/z257/belisensis/BOSEPLUG.jpg)
Thanks Rob as I am not cutting anything today will look closer at these leads, I have plan B so al should be well ;D and at least I know what it is now.
