Chat Area => General Discussion Area => Topic started by: TheBoy on 08 September 2012, 20:05:45
Title: Identify capacitor
Post by: TheBoy on 08 September 2012, 20:05:45
Any of the electronics geeks able to identify this cap?
(http://i14.photobucket.com/albums/a319/IamTheBoy/CF1F4D67-22B3-46CD-9DAB-238D2C640190-13067-00000790FCD9580E.jpg)
Title: Re: Identify capacitor
Post by: Taxi_Driver on 08 September 2012, 20:55:17
Its about time you bought a new bike anyway  ;D
Post by: TheBoy on 08 September 2012, 20:59:39
I was thinking earlier, before I checked it over, I should just sell it, as I can't really use it at the moment anyway...
...but I reckon if I did, I'd never ride another bike again.
Post by: Taxi_Driver on 08 September 2012, 21:01:30
Apparently a 1000uF 16v will work, but the flash is a bit quick......increasing the value is suppose to prolong the flash  :y
Post by: Andy H on 08 September 2012, 21:07:57
Seems odd. That electrolytic capacitor looks big enough to carry at least uF and V markings :-\
the markings are probably on the other side.........
Post by: TheBoy on 08 September 2012, 21:09:07
Nothing on other side
(except -ve marking, just visible)
Post by: Martian on 09 September 2012, 10:05:58
Dunno what the exact value is, but you can find the same cap in turn signal relays on most Kawasaki's
Post by: TheBoy on 09 September 2012, 10:08:55
Looks like a replacement relay is only a fiver, delivered, from ebay.  Probably not worth messing around trying to find a suitable one.
Post by: zirk on 09 September 2012, 14:07:07
If its a Indicator Relay, then guessing 16 or 20 volt rating, so any Electrolytic roughly the same size with a similar rating should work.
Or if you know the Relay switch over voltage, you could work out the charge / discharge time from each flash and from the resistor value to give the Farads.
Or just buy one for a Fiver. ;) but guessing youve probably got a cap laying somewhere on a board.
Post by: Martian on 09 September 2012, 17:49:39
Physical size of the can means jack, it's the actual values of the cap that matter as that is directly responsible for the timing of the flash rate (currently between 60 and 120 flashes per minute as far as UK law states).
Post by: Auto Addict on 09 September 2012, 19:25:40
http://static.schneider-electric.us/docs/Power%20Management/Power%20Quality%20Correction%20Equipment/Medium%20Voltage%20Fixed/D5840BR0001EPR1.pdf
Post by: Martian on 09 September 2012, 19:56:42
A 1000m drum of Pyro given a 3 second dose of a 1KV insulation test achieves the same result when some poor fool grabs hold of the end  ;D ;D
Post by: Steve B on 09 September 2012, 22:07:03
penny licker ;D ;D ;D ;D
