Omega Help Area => Omega General Help => Topic started by: philsteward on 30 September 2012, 08:22:31
Title: Gearbox selector issues
Post by: philsteward on 30 September 2012, 08:22:31
Hi all.
Bit of help please, have had a good search around but not found what I need. All of a sudden on Thursday noticed that the gearbox lights were flickering like a Christmas tree. Drove car on Friday, and they got very bad, then the car with the spanner came on and box went into limp mode. Switched off and all fine, but kept going into limp mode.
Checked fault codes and it has stored a pending P0705 code. Followed the guide to clean out selector, looked okay inside, plenty of grease and not broken electrodes, cleaned out and regreased fitted and adjusted but problem not gone away. It is much better, but still flickers a bit but not gone into limp mode yet.
Questions - what grease should be used for the selector switch?
A lot of heavy rain recently, could that be the issue? If so to note the switch was bone dry inside.
Fault not fixed, although selector looks okay, is this still likely to be the issue?
Back ground info, ATF changed at 80k as routine maintenance, 10k ago. Refilled with Fuch Titan stuff from Opie Oils, filter changed too. Level has been checked and all okay.
Many thanks in advance!
Title: Re: Gearbox selector issues
Post by: noel on 30 September 2012, 20:39:14
water ingress could be the problem  :-\  as for grease a smear of vasaline should suffice HTH  :y
Post by: philsteward on 01 October 2012, 22:38:36
Thanks for the reply.
No other suggestions of how to proceed? If it is water ingress then is the only solution to replace?
Post by: Kevin Wood on 02 October 2012, 09:10:55
Switch can often be removed, cleaned up and lubed with a little Vaseline. Worth a try as it's expensive new. There's a maintenance guide covering it, I believe. :y
Post by: philsteward on 02 October 2012, 13:14:22
Have already tried that, made it a bit better does not go into limp mode anymore but still flickers, so assuming it is only going to get worse with use.  Used contact cleaner to clean up the switch, and applied silicone grease from Maplins to all of the inside and the seal.
Is there a way to test the switch and its contacts?
How do you remove the other half of it from the car, the half with all the electrics on!
Cheers
