Omega Help Area => Omega Electrical and Audio Help => Topic started by: Jay30685 on 03 October 2012, 21:48:21
Title: headlamp bulbs....
Post by: Jay30685 on 03 October 2012, 21:48:21
Can anyone tell me what bulbs are meant to be in an omega? My headlamps are really dull. They have bulbs with 2 prongs, the wires going to bulbs are just wires with spade connectors on.
My car has previously been a taxi so a couple of cheap repairs have been done
Title: Re: headlamp bulbs....
Post by: Andy B on 03 October 2012, 21:53:04
http://www.omegaowners.com/forum/index.php?topic=90457.0
 :y :y :y
Post by: 05omegav6 on 03 October 2012, 23:15:06
Sounds like someone has possibly put 24volt bulbs in ::) half the voltage and half the brightness :-\
Post by: bored bigyin54 on 04 October 2012, 01:08:18
i got candels on mine as well ;D ;D
Post by: Jay30685 on 05 October 2012, 18:50:21
Thanks for help guys, I've got H1 bulbs fitted, 12v 80w, but are really dull. The wires look a bit burnt  has anybody had this problem? Need to get it sorted as nights are drawing in
I've taken pics but need to get Photobucket downloaded on my phone
Post by: RobG on 05 October 2012, 19:34:14
You sure, standard fitment are 55W
Post by: Jay30685 on 05 October 2012, 19:39:46
Yeah that's definitely the one, 80w wouldn't make them dull though, or burn the wires
Post by: RobG on 05 October 2012, 19:59:46
Running 80W bulbs they will
Post by: albitz on 05 October 2012, 20:08:09
Sounds like someone may have installed overpowered (and illegal ?) bulbs to try to compensate for milky headlamp lenses,and the power they are drawing is too much for the wires ?
Post by: Martian on 05 October 2012, 21:05:18
Yes it will, and if the wires are burnt then they will want replacing as well.
Post by: Jay30685 on 05 October 2012, 21:11:55
I've run 100watt bulbs and never burnt wires before, the cables are more than adequate
Post by: Martian on 05 October 2012, 21:32:57
I can assure you they aren't, which is why yours are showing signs of distress already.
Post by: tunnie on 05 October 2012, 21:38:55
In the 2.2, I run these: http://www.ebay.co.uk/itm/Osram-Night-Breaker-Spotlight-Bulb-x2-H1-448-55W-VAUXHALL-OMEGA-94-01-/280908470885 (http://www.ebay.co.uk/itm/Osram-Night-Breaker-Spotlight-Bulb-x2-H1-448-55W-VAUXHALL-OMEGA-94-01-/280908470885)
Huge improvement over what was in there before (think they were original genuine) The light is thrown much further forward.
As already said, running high rated bulbs has not done the wiring any good
Post by: biggriffin on 05 October 2012, 22:50:21
Its mainly the switch which will give up in a puff of smoke as GM wiring does not like 100w blubs.
  back in the day during the war the mantas with light pods and headights used 120w lucas blubs with a relay per light plus suitable wiring looms.
Post by: Jay30685 on 05 October 2012, 22:59:11
Oh right, I've never really owned Vauxhall before, mainly Peugeot, Citroen and 4x4s.
I think I've found the problem, the earth terminal is very rusty. I'm going to remove the headlamps over the weekend,  replace the wires and terminals then I'll buy the above tried and tested bulbs
Thanks for all input, I will update when I've done them
Post by: mindaz on 08 October 2012, 09:20:09
short question
can I remove fog light bulbs without removing front bumper ?  ???
thanks  :y
Post by: RobG on 08 October 2012, 09:24:52
short question
thanks  :y
Yep
Post by: mindaz on 08 October 2012, 09:26:38
ok, thanks Rob  :y
will try
Post by: RobG on 08 October 2012, 09:28:03
Just reach up to them from underneath. 1/4 turn and the bulb pulls out.
Post by: Rich-K on 09 October 2012, 14:31:13
For the past few years I have run with 100w on main beam, with standard 55w on dipped.  Just uprated the fuses for the main.  Most Vauxhalls have seperate fuses for dip and main for each headlight. (ie 4 seperate fuses for haedlights). As a general rule of thumb twice the watts equals twice the amps.
Post by: dbr on 21 October 2012, 23:24:02
found this
The conversion of Watts to Amps at fixed voltage is governed by the equation Amps = Watts/Volts
Post by: Martian on 21 October 2012, 23:27:56
found this
That'll be your basic Ohm's Law at work.
Post by: dbr on 22 October 2012, 00:16:08
found this
 about 40yrs ago, I was learning about that. Now it will be 'if you and Zenab held etc
Post by: TheBoy on 22 October 2012, 08:54:49
Remember, the fuses are there to protect the wiring (only), and should be the weakest part of the circuit for current.
Unless you have proved the wiring and switchgear is certified for the higher current, you should never up the fuse sizes.
