Omega Help Area => Omega General Help => Topic started by: geoffr70 on 07 October 2012, 00:15:55
Title: Throttle lube
Post by: geoffr70 on 07 October 2012, 00:15:55
Hi peeps, can anyone recommend what sort of lube I should use for my throttle cable and bodies? I've had them off loads of times obviously when cleaning and doing work. I think the TBs are sticking a bit, which is annoying when pulling away due to it being automatic. Will a light GP oil be ok? Oh, and grease for the cable, the spring bit? Thanks peeps.
Title: Re: Throttle lube
Post by: zirk on 07 October 2012, 00:28:56
TB's rarely stick, as the spring is too strong, unless its lose, if so clean with Carb Cleaner, chances are your ICV needs cleaning.
Chris. ;)
