Omega Help Area => Omega General Help => Topic started by: uktigger on 25 October 2012, 13:09:03
This may be a silly question, but what is the purpose of the Heater Bypass Valve?
Reason I ask, i've got a 2003 2.2CD and had my HBV replace about 9 mths ago after the dreaded leaking.
Was chatting with my neighbour who has a 2001 2.2CDX, who told me he had just had the same problem - however he had not had a new valve installed. Instead he had just taken the old valve out and replaced it with some "T" pieces to join the pipework.
Will this cause him and problems?
Steve
It diverts coolant flow back to the engine when heat is not needed, eg with cc on lo.
so will he have any problems due to not replacing like for like?
(http://i15.photobucket.com/albums/a384/themarbleintheoatmeal/smilies/watchdrama8jm.gif) ?
This is interesting to me too, I still haven't replaced mine, I just keep topping up with coolant when the dash warning comes on!
No. Only difference will be that the air con won't blow quite as cold in summer, as it won't be able to stop hot water circulating in the heater matrix.
Block up the vacuum pipe, though, so you don't get an air leak. :y
not wishing to hijack but i have the HBV i pulled off ralf in prep for it happening in the future. is there any way to keep this ''serviced'' for before it gets (if at all) installed in the ve-hicle? maybe a shot of carb cleaner? :-\
Nah,its only a bit of plastic.Wash it out with soapy water,leave it to dry and then store it somewhere until you need it.
thanks albs. youre one of the best!!! :-* :-* :-*
There's a rubber membrane in the hbv. Might benefit from some silicon spray. No carb cleaner though, it's plastic and rubber, which will likely melt.
http://www.omegaowners.com/forum/index.php?topic=105900.0
Soon as mine leaks again its going in the bin then , no air con in mine as the condenser is in the bin anyway :y
Thx very much - the advice on here is always appreciated :-)
It wont get as warm either (as the flow through the matrix will be much less as the return path will be less restrictive) and aircon wont get cold.
