Omega Help Area => Omega General Help => Topic started by: Andy B on 12 November 2012, 19:42:28
Just drove back home from work in the Omega (used it all week :y) and as I was going slightly down hill, I was aware that it was rev'ing more than required for the speed. I didn't notice to start with cos the radio was loud-ish & I was miles away :-\ :-\ but it then did it again going slightly up hill. I tried to make it do it again, but it wouldn't. :-\ :-\ :-\
My first thoughts were low ATF, but it's recently had the rear crank shaft seal replaced & I supplied the garage the best part of a gallon of the stuff to top it up if required - I know that's not a guarantee that hey actually checked it though.
Any thoughts other than the easy check of low ATF/ :-\ :-\
They might not have checked it at all .. OR .. they checked it with the engine off..... :(
First thought is a PROPER ATF check .. if it does nothing else, it rules out low fluid, which is the cheapest fix anyway .....
Firstly unless you phyically saw them check it i would say check your level plus how old is the current ATF ?
Hope its not the gearbox althoughits not a hard job to replace tbh :)
Worth a level AND leak check. Engine running as said. :)
It has been done fairly recently .... a few summers ago :y. Can't remember exactly :-\
(http://i84.photobucket.com/albums/k17/Tiff4327/Omega/Image018-1.jpg)
Weather pending these next few days I'll try to have a look. :y
Perhaps it's just had a minor fit due to being used every day this week. ::) No ATF leaks on the drive though.
Merc's had its new Airmatic (suspension) pump now & is back, so Omega can rest again. :y :y
Mine does it every now and then - I just ignore it. ATF was checked and found ok.
Thanks ....... I'll ignore it ;) ;)
