Chat Area => General Car Chat => Topic started by: Lizzie_Zoom on 14 November 2012, 17:30:08
Well the replacement DIS pack is now fitted and the engine itself is at last running well :y :y
However, according to the local exhaust specialists who have now inspected the system, one of the middle exhaust boxes has blown (probably due to the misfire), with a "bulge" on top and will be replaced for £118 once I have the money next week, with an MOT thereafter! The professionals can do that job!
Although I scratched my arms to buggery again, you can see the void where the old DIS pack was. As a point of interest, you will note I did not have to remove the wiper motor, but on the advice of TB it really helped taking the cables out of the plastic tray and moving all out of the way with greater flexibility. :y :y :
(http://i282.photobucket.com/albums/kk247/lizziefreeman/DSC00244.jpg)
The old DIS pack was definitely the problem!:
(http://i282.photobucket.com/albums/kk247/lizziefreeman/DSC00245.jpg)
............and the replacement (a Bosch) about to be installed:
(http://i282.photobucket.com/albums/kk247/lizziefreeman/DSC00243.jpg)
Overall this exercise was VERY satisfying and took a relatively short amount of time. 8) 8)
I just wish I had replaced the DIS pack with the replacement spark plug leads all in one go.
How many times I have stripped the bits off the top of the engine over the last few days I have lost track, to add to all the numerous previous occasions. I reckon I could now do it all blindfolded!! ;D ;D
Thanks for all the useful comments I received :y :y :y :y :y :-*
I know one thing, without the OOF and associated diagrams / advice / maintenance guides, I would not have had the confidence to complete this work :-* :-*
I was 'trained' of Austins, Morris's and early Fords, not the 'new' nightmare cars with multiple leads / pipes / sensors everywhere, and the blessed plenum in the way. On the older cars I could strip and engine and rebuild it in a day, but with these beasts you cannot even test the engine running without putting so much back before you do! ::) ::)
But we love the Omega really! :D :D ;D ;D
well done Lizzie :y
Aye well done :y I remember that fitment well .... have scars to prove :( ;D
Well done, Lizzie. On posher Omega's we have coil packs.... ::) ::) :-* :-* :-*
Snob! ;D ;D ;D ;D ;)
I'd be inclined to get a decent cheap exhaust from Eternal (about £100 for the 3 pieces).
Not a bad job to change, just be aware the front bolts can shear, needing a drill and a tap set.
Right. Thanks TB. :y
Where do you get those "Eternal" exhausts please?
Well done LZ :y.
Well done LZ :y.
Thanks :y
How are you doing now?
Well done LZ :y.
Thanks :y
I'm very good thanks for asking. Everything is going well in my world at the moment :y. Seen you buzzing about a bit lately :y. How's yourself?
Well done LZ :y.
Thanks :y
Now the car is almost fixed, I am well thanks :D :y
Haven't seen you, but I do not know what car you are now driving. Still with BMW's?
Well done LZ :y.
Thanks :y
That's good, anything you need, you know where I am :).
Going around in an 11 plate 5 Series at the minute :y. Many, many BMW's at the minute, car selling is going through a real slow spell :(.
Well done LZ :y.
Thanks :y
That's ice! 8) 8)
I will watch out for you, once I am back on the road :D
Well you live and learn, I didn't realise there was a 3.0 facelift! thought they were all 3.2
Early facelift v6,s were 2.5 & 3.0,then changed to 2.6 & 3.2 - around 2001 iirc.
I probably have to do this dispack change (and stat change) myself sometime in the not too distant future.Got a misfire sometimes on gas and as I have a spare dispack might as well change it to find out if thats the cause.
"Congrats" and well done! :y
No those built in 2000 and I believe up to 2002 were 3.0's. The 3.2's were a late addition.
On egay, search foe eternalcar. There sites are ropey, but they do respond to messages sent early in the day
2001 :)
Thanks :y
:y :y
..............and to think with mine it all started with a service, a plug lead falling apart, and me trying to repair it, with afterwards starting the engine and running it with a misfire!! ::) ::) ::)
That will teach me not to be so stupid and use my mechanical brain :D :D
Got a spare set of leads too.Thing is do I change them at the same time ? Might see what the old dispack looks like when it comes out and see how lucky I feel that day. ;)
I would now, with hindsight, replace all at the same time.
My DIS pack was certainly on the way out with or without my spark lead / misfire problem. Just look at the right hand side of the picture:
Probably caused by water leaking onto it from a leaky scuttle. ;)
I think its heat build up as look were they put the stupid thing!!! >:( silliest most stupid place
First job to do is check for scuttle leaks after fitment and seal up so you dont have to replace sometime soon again :)
Its 12yrs old, and done X miles, it probably hasn't done so bad, esp if it was firing a failing lead :y
That said, MV6 is still on its original, so they can last 14yrs/192k
Aye , im sure mine was the original as well . Water was dripping onto mine :) cant see the car lasting another 15 yrs but you never know ;D
Well done Lizzie, glad you got it sorted, hope the arms soon heal.
Nice one LZ............ :y :y
Yep! As with a lot of design features on these V6's. :-X
As said before even the dear old Austin mini was easier to work on for access to the plugs, leads, distributor, dynamo, water pump, etc! ::)
Yes I agree TB, the old DIS did well for 12 years and 125k miles.
Tend to regularly clear out the scuttle drains Albitz, and in fact never found water around the area.
So do I. along with the hands and legs! Savlon and Moisturiser is being applied very liberally ;D ;D
Nice to see you back Lizzie :y :y
Not connected to scuttle drains.The water leaks at the scuttle join,about two thirds of the way across the scuttle towards the nearside.Then runs down into the rear of the engine compartment,attacking the dispack or the rearmost part of the coil pack on DBW engines. Solution is to seal the join with silicon sealant.
Top Job LZ. Well Done! :y
I wouldn't even consider doing that job!
Thanks :y
It was remarkably straightforward really 8) 8)
