Omega Help Area => Omega General Help => Topic started by: maryso on 16 November 2012, 20:35:57
heating blowing cold, gggrrr, help please???
Was it hot & now it,s just cold or has it been cold only & no heat for a while ?
The more info you give the more chance the experts on here have of diagnosing the problem .
What year & which engine would help to start. Any coolant leaks at all etc.
With full input from you they will hopefully get to the bottom of it :y :y :y
omega 2002 gls fan working but just cold air!!! picked it up from ex husband 2 days ago so no idea if it was working, coolant etc all full, no leaks xx
and please dont ask me to call ex, !!!! >:(
reckon HBV not working -if heater worked now doesnt-or thermostat stuck
Temp gauge working ok? Might point to stat ....
Do you know which engine you have ? V6 or 4 cylinder ?
Is engine temp gauge running at normal mid position ?
Could be something as simple as a vacuum pipe off . :-\
Someone more knowledgeable will be along shortly.
There is an Omega meet in Kent tomorrow I think , West Malling ME19 area if you are fairly near . someone there would almost certainly have a look for you . :y
Check out the meetings page
check water level in expansion tank-if low that could cause problem too if v6 check small vacuum pipes to/from brake servo-they split on plastic T pieces and that stops HBV=no heat
temp gauge ok
thanks for that, top tip, will look up the meeting!! temp gauge ok
4 cylinder
Vacuum is used to turn OFF the heat, so no vacuum equals heat.
Whip the small vacuum pipe off the top of the HBV, and plug the end of the pipe with a small bolt, leaving the "stub" on the HBV open to air.... see if you then get heat.
If you can't find the HBV pop to the meet and get one of the guys to do it !!!
i'll give it a go, but more likely to rock up to the meet looking helpless!!!
Go to the meet chick the lads are sure to help a damsel in distress :-*
Sorry you to far from me otherwise I'd come and have a look for you
bless you!!!!! total numptie when it comes to cars, time i learned!! xx ::)
