Chat Area => General Car Chat => Topic started by: Webby the Bear on 18 November 2012, 19:31:26
Title: Quick (hopefully) breather question :)
Post by: Webby the Bear on 18 November 2012, 19:31:26
Hi guys,
Did my breathers today. Took my time, couple of tea breaks, took 3 hours. Long time but as I said I took my time and really enjoyed working on the old girl  :y
Now for those who have seen some of my posts you know I've been experiencing some fuel loss issues. I worked out that I was getting 19.5 MPG.
SO.
When I did the breathers today I found two things:
1.) the main 'Y' pipe wasn't secured; I'd previously replaced the hose clamp with a jubilee clip because it was awkward to get pliers or similar in to that space to ''place'' the hose clamp.....this was spinning freely round the where the 'Y' pipe connected to the breather box and therefore wasn't secure.....so I put the old clip back  :y
2.) the pipe connected to the breather box furthest to the right AND THEN connected to the breather bridge third along (as you look at it) was really cracked at both ends  :o........ SO i replaced it with one pinched from ralf. However it was one I'd modified  ::) it was ralf's pipe that fitted first on the breather box (left to right) and seemed slightly bigger diameter than the last one (left to right). i trimmed it and so far no leaks or anything like that.
Will i, do you think, experience problems with this modified pipe in the future? like for instance the pipe being easily forced off by the oil pressure....... although i am sure someone said the oil pressure from the breather box to the breather bridge is low?
cheers guys
Title: Re: Quick (hopefully) breather question :)
Post by: Entwood on 18 November 2012, 19:36:37
Hi guys,
SO.
cheers guys
Slap a cable tie on it .. in fact .. replace all those horrible clips with cable ties !! I secure all 4 breather pipes with cable ties .. there is no great pressure and no fluids to leak ... so  a cable tie just keeps everything secure... easy to remove with snips, and cheap to replace the next time :)
Post by: Webby the Bear on 18 November 2012, 19:39:00
Hi guys,
SO.
cheers guys
exactly what i was thinking!!! cheers mate  :y :y :y :y
Post by: omega3000 on 18 November 2012, 21:04:18
How many more bits you got stashed away from ralf  ::) ::) All come in handy though dont they  ;)
Post by: jonny2112 on 18 November 2012, 21:30:09
On my MFL the two internal pipes were the same diameter, whereas on the FL there are different sizes.  :-X
