Omega Help Area => Omega General Help => Topic started by: migman on 13 December 2012, 18:00:49
Title: wheel nuts
Post by: migman on 13 December 2012, 18:00:49
Hi guys can you tell me if i need a special tool to take of the wheel nuts i have a facelift yr 2000 2.2 auto fitted with alloy wheels thank migman ;)
Title: Re: wheel nuts
Post by: Andy B on 13 December 2012, 18:04:21
Just a deep 17mm socket or the wheel brace that Vauxhall put in the boot.  ;) ;) ;)
Post by: Lazydocker on 13 December 2012, 18:35:26
You might have a locking wheel nut though :-\
Post by: TheBoy on 13 December 2012, 18:36:15
Aye, depends if you have a locking wheelbolt, in which case you (ideally) need the correct key.
Post by: twiglet on 13 December 2012, 19:53:43
Also answered this in your other post...
It depends if you have locking wheel bolts or not.  You'll probably have plastic caps over them, so you need to pull them off to see the bolts.  The standard bolts are 17mm.  If one on each wheels looks different, then they'll be the security locking ones, which you should have an adaptor for.
If you don't have the adaptor, then the fun and games will start.
Post by: kevinp58 on 13 December 2012, 22:02:10
When I got my bargain a few months ago there was no locking nut tool with the car so had to get new one with new bolts £30 from dealer. to get them off you need to get a small cold chisel and break the outer ring off first then hammer an impact socket onto the remaining nut and then it should come off  :y
