Omega Help Area => Omega General Help => Topic started by: Lookitt on 31 December 2012, 11:50:04
Hello, sorry for my english, I'm french. :-X
I've a x30xe of 2000, and to open the truck from inside, I should remove the key and push the button of trunk. How can I open the trunk without turn off the engine and remove the key ?
Thanks
The 2000 model, you have to remove key from ignition :(
Options are to change the alarm ECU (not starightforward), or do "Hillpers Boot mod" which has some unfortunately side effects.
This was a feature of early facelifts, you cannot open boot (trunk) within ignition on. Later ones allowed a 3 second push to do this, as it was a very annoying feature.
You can modify it so it does work with key in ignition:
http://www.omegaowners.com/forum/index.php?topic=90516.0 (http://www.omegaowners.com/forum/index.php?topic=90516.0)
Itīs ok, I've done as it was explained in the link. Itīs all right. Thank you very much for your help and your quikly answers.
... or do "Hillpers Boot mod" which has some unfortunately side effects.
Out of curiosity, (and having only ever owned estates), what are the side effects :-\
Can think of one significant one, feel free to PM rather than post if my thinking is correct :y
Delay time on interior rooflight is increased
That it :-\ I'm almost dissappointed ;D
Wasn't my first thought...
2 downsides, the bloody courtesy light doesn't go out when you start the car, and its ever so easy to accidentally pop the boot which fumbling for the CDC button ::)
That's my new thing for the day 8)
