Omega Help Area => Omega General Help => Topic started by: gpenny07931 on 05 January 2013, 13:40:11
Title: changing plugs
Post by: gpenny07931 on 05 January 2013, 13:40:11
Got the leads off and realised the plug wells are full of oil. Is it a bad idea to remove the plugs?
Title: Re: changing plugs
Post by: tunnie on 05 January 2013, 13:42:22
No leads on 2.2, you mean the coil pack?
On 3.0 Estate they were full of oil so I used an old spray bottle sucker bit to draw most of it out, others say just sod it and let it dump into the bores.
Will smoke a fair bit though on start up  ::)  ;D
Post by: Taxi_Driver on 05 January 2013, 13:43:10
IMO no it doesnt matter, but it does mean you need to change the cam cover gasket
Post by: tunnie on 05 January 2013, 13:44:32
make sure you use a genuine gasket & follow the guide  :y
Post by: Lizzie_Zoom on 05 January 2013, 14:42:27
I tend to use kitchen towel to suck the oil up, but thank God I have not had that problem for a long time! ;D ;D ;D ;D ;)
..........and Taxi Driver is right: you certainly need new cam cover gaskets plus the breather system blown threw thoroughly with carb cleaner. ;)
Oh, and also change the oil afterwards! :) :)
Post by: gpenny07931 on 05 January 2013, 15:19:23
Got it sorted. Also filled the street with a cloud of smoke. Will get the gaskets ordered. Cheers.
Post by: omega3000 on 05 January 2013, 18:40:26
 ;D
Post by: Webby the Bear on 05 January 2013, 18:45:59
turkey baster to get the oil out.
or if like me your mrs is a nurse then syringe it  ;D
Post by: martin42 on 05 January 2013, 18:47:59
i just use some old rags  ;D
Post by: amba on 05 January 2013, 19:14:15
Syringe with a thin peice of tubing then bit of kitchen roll pushed down into the well with a long thin screwdriver.
