Chat Area => General Car Chat => Topic started by: OOMV6 on 22 January 2013, 06:41:15
Re: this thread http://www.omegaowners.com/forum/index.php?topic=103255.msg1292450#msg1292450
Stay away from the Peugeot 807, 2004/5 model anyway
Oh dear! I take it you got your fingers burnt then ??? :(
I know, I was warned about French cars, but to date, I have only had good experiences with them. This one has been trouble.
The trouble started when the engine management light kept coming on and cutting the power from the turbo. It has been back 4 times, and they've checked, changed this and that, tested, but cannot isolate the problem.
The guy has said that the electronics (especially in these cars) can cause the problem. Basically the electronics detect an unusually high gas levels (clogging up of cat, ultimately) and send it into limp mode. This clears itself after the car has stood for a while - sometimes light goes out, sometimes not, but power does return.
The seller has said you need we need to drive it a little harder to avoid build up in the cat. Ok, it does only do the school run generally (25km each way twice a day) but you should be able to potter along in 5th at 2000 rpm without worries. My good lady does not drive like a grandma - doesn't wellie it either - but no other car driven like this causes this problem, so I ain't buying that excuse. And I certainly ain't burning more fuel just the car wants to be driven harder.
On top of that:
- Airbag light for passenger airbag came on – has gone off again since.
- On one occasion, the seat belt buzzer started whilst driving. The driver had their seatbelt on and there was nobody else in the car – and no weight on the passenger seat.
- The right front indicator works randomly. Sometimes it flashes, sometimes, it does not.
- Rear washer. The pump is working and the waster is flowing – just not onto the rear window. Don’t know where the water is going.
- The car has a healthy appetite for headlamp bulbs. I have changed 3 in the time we have had the car.
- Even after having the glow plug relay changed, it still is a struggle to start in the mornings. It never starts first time, even after several turns of the engine
Furthermore, I have always had my suspicions about the power delivery from the turbo. Instead of sounding like a continuous whistle, it is sounding more like a police siren.
So, the seller is looking for another car for us. His service has been good, taking the car back in, and now getting us a replacement, although he is taking his time.
