Omega Help Area => Omega General Help => Topic started by: sport on 28 January 2013, 11:47:38
Steering wheel how to remove it and what tools do i need on my 03 omega
thanks
Iirc...
Ignition off, keys out
Two torx from the back to remove air bag
remove air bag wires
Push lock washer tabs down
Undo centre nut
Knees and one hand pulling on steering wheel so it's under tension
With free hand, short sharp hard tap on centre shaft
Sw should pull off, mind it doesn't smack you in the face. ;)
Iirc...
Undo centre nut
Hi what size center nut is it thanks
Cant remember off hand. It's a two minute job to remove the torx and have a look. Just make sure keys are out. ;)
Remember to mark the relative positions of wheel and shaft before removal and replace as found. :y
And don't put them back until its all back together or you'll need Tech 2 or similar to kill the light :y
If you struggle by hitting it etc, the proper puller is like this ....... http://www.ebay.co.uk/itm/Vauxhall-Steering-Wheel-2Leg-Puller-Pulling-Removal-Tool-/160661958527?pt=UK_Hand_Tools_Equipment&hash=item256832ef7f ;)
And be careful it doesnt smack you in the face when it suddenly loosens its grip on the splines. ;)
Leave the nut on the last couple of threads until steering wheel is loose. :y
Should have remembered that myself. :-[ :y ;D
I tend to remember things like this for life after pulling my top lip back out of my teeth. ;D ;D
Ive removed enough Omega steering wheels to have no excuse for forgetting. ;D
I broke my two front teeth last year,but that was while messing around with a rear seat belive it or not.It could only happen to me. ;D
Ah 'dangle berries', what a bloody good idea, as it bloody hurts :-[
Thats why you look like that then.I had assumed it was an accident of birth. ;D ;D
He's had enough abuse tonight Albs. Just think, he won't give me my posts back won't be happy if he gets too much abuse
You silly arse, Albs, your weren't looking at me, your were looking in a mirror :P ;D
