		Omega Help Area => Omega General Help => Topic started by: scottambrose on 31 January 2013, 13:01:09
				when changing my rocker covers i noticed the coil pack on the passenger side had some rust around one the legs at the top. and yesterday i had a random misfire which went when i turned the car off and back on again. its the second time its done this in 4 months and all i get in the code is random misfire for those 3 cylinders. i can get a bosch coil pack for 65 pounds new. are bosch ok and is it likely going to be this at fault?
				Probably and Bosch OK :y
maybe you can borrow from friend to test before you buy?
I still fight with my misfire
http://www.omegaowners.com/forum/index.php?topic=111227.0 (http://www.omegaowners.com/forum/index.php?topic=111227.0)
				The misfire is set iff by hard acceleration and as soon as you turn the engine off and re start its fine
				make sure it really is a Bosch one - there are plenty of ebay specials masquerading as Bosch.
Bosch were the OE manufacturer
+1 :y
Thats cheap , i was quoted £90 for the bosch last year .
				If you can get genuine Bosch for that price get them. Usually they are over £100.
I found these on eBay - search for item listing 290576054834.
I got a 2-4-6 in December 2011 and it's lasted so far.
Make sure you seal the scuttle as described elsewhere on OOF - it really does make a difference in stopping the water dripping on the pack and in the plug wells.
				I xan order direct from bosch through my work
