Omega Help Area => Omega General Help => Topic started by: kevin xf on 31 January 2013, 17:14:28
Title: Omega headlight switch
Post by: kevin xf on 31 January 2013, 17:14:28
Hi all.   I fitted led fog bulbs about 6 months ago.  I'm now having problems with headlight switch.   When I turn my lights off my doors lock  :-\ !!!    Would fitting them bulbs overload the headlight switch ?  I also had to take the interior bulbs out as the over head interior light was staying on.
Title: Re: Omega headlight switch
Post by: steve6367 on 31 January 2013, 17:28:04
LED would be lot less load than those they replaced - sometime not enough load can cause problems though.
Change back to the OEM and see what happens?
Steve
Post by: kevin xf on 31 January 2013, 17:42:05
Thanks Steve.  It's not been right since my mechanic left the door open causing the battery to go flat. He replaced battery with a spare he had as he killed mine.  Since then when I unlock the doors  and open drivers door the doors lock!!  It's now stopped doing that and know looking the doors when I turn the lights off.   I disconnected the power sounder would that have anything to do with it??    I replaced fogs with led cos it was cheaper to buy a pair of LEDs than1 standard  fog bulb  :-[
Post by: steve6367 on 31 January 2013, 17:47:57
The problems sounds more like water in a connection somewhere or maybe a poor earth?
Is it when you switch the LED fogs off? Or the main headlights?
Steve
Post by: kevin xf on 31 January 2013, 17:53:34
When I switch the main lights off.  Soon as the switch hits 0 the doors lock.
Post by: symes on 31 January 2013, 19:55:35
Power sounder not to do with your problem mate-if mechanic left door open long enough to flatten battery that was a few hours mate probably door switch gone mate. or light switch TBH I would bet light switch--dont ask-numbnutz me did that lucky I got spares mate
Post by: kevin xf on 31 January 2013, 19:57:18
Thanks symes  :y
Post by: symes on 31 January 2013, 20:04:06
Have door switch here in my pit workshop or just take one from spare mig for you if you want mate :y think I got light switch too but cant promise on finding it though mate :y you welcome to try-if it helps :y
Post by: kevin xf on 31 January 2013, 20:09:33
Ok mate will have a look on sat.  :y
Post by: symes on 31 January 2013, 20:17:08
you might find my car in there ;D ;D ;D ;D its a f^^d
