Omega Help Area => Omega General Help => Topic started by: MV6Danny on 02 February 2013, 16:13:29
Hi guys. I am a bit P***ed off. I bought a new steering idler from the bay and fitted it. Took the car all the way to wheels in motion to get the geometry done only to be told that the idler is loose. The guy showed me the play in it and it was loads. Could this be the mount that the idler sits on that has gone or do you think it could be a faulty idler? Is this a fault that is common on the omega? Hope somebody can help with this as am really p***ed now. Traveled all that way for nothing :'(
Genuine from the bay will be around the £45 mark
http://www.ebay.co.uk/itm/Vauxhall-Steering-Idler-Arm-110mm-9195731-Fits-Carlton-Omega-/190778975875?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c6b502683
didnt buy genuine. Will that make much difference then?
May`s well have fitted a Mars bar then. Well documented here that aftermarket idler arms are unadulterated shite
I'll send it back then. Says it has a 12 month warranty on it.
Bay link or from here (Jason) http://www.allgermanparts.co.uk
I bought this one http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330855263355#rpdId
I will get it from http://www.allgermanparts.co.uk/ or the other ebay link in previous post.
Could it be the mounting that the arm slides over causing this or not?
You won't know until you fit the "correct" oe idler. Unlikely though ;)
hopefully its not gone as wouldnt know where to get one from. I have ordered another idler now. all german parts are out of stock so got it from the bay on the link above. :y
If its a pattern idler, that will be the failure, more than likely.
Never heard of the bracket failing, but there's always a first time. I suppose.
I had free play between inner sleeve and axle. If idler arm axle is worn out, you can buy 100 arms from different manufacturers and get mad at them. I used JB Weld (epoxy), problem solved, but I was told it was wrong.:)
What is that and what did you do? Also where do you get it from? Thanks :y
I used Kwik Weld.
http://www.jbweld.com/
You need to find out where free play is. Most likely I had worn out idler arm axle.
Free play can be between 2 parts: arm/outer sleeve/rubber/inner sleeve/axle.
