Omega Help Area => Omega General Help => Topic started by: greenman on 04 February 2013, 16:46:13
Title: misfire
Post by: greenman on 04 February 2013, 16:46:13
Water in plugwell no.4 caused misfire.
dried it out,misfire cleared.
water was clear so not coolant(red)
2.2 facelift.Seem to remember something about rainwater getting
in somehow.
any thoughts?
Title: Re: misfire
Post by: RobG on 04 February 2013, 16:51:34
Scuttle join likely culprit
Title: Re: misfire
Post by: greenman on 05 February 2013, 09:59:25
Any advice on how to cure this?
Title: Re: misfire
Post by: tunnie on 05 February 2013, 14:16:21
As Rob says above, the scuttle join point or the base of the wiper arms is letting water through.
This drips onto cam cover and into pot4, feel under the foam to see where its wet.
But a dab of clear sealant around wiper arms should fix it, but also check join point  :y
Title: Re: misfire
Post by: Mart280 on 05 February 2013, 20:41:00
My scuttle was leaking like a waterfall, as Tunnie said sillicone the joint, I also sealed the joint from  underneath with a couple of strips of Denso tape and it leaks no more :)
Title: Re: misfire
Post by: greenman on 06 February 2013, 11:42:33
Dried out,sealed as said.
Here,s hoping!
