Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: tunnie on 05 February 2013, 17:52:13
Title: Washer Feed pipe joiner
Post by: tunnie on 05 February 2013, 17:52:13
I managed to snap the little connector for the washer fluid pipe, that sits in the engine bay. It joins the feed from the pump, with that feed pipe from the scuttle. The one about half way up, near the suspension strut.
I blame -18 temps rather than my temper  ::)
Just need that so I can rejoin the two pipes & dispense with my bodge!  :y
Title: Re: Washer Feed pipe joiner
Post by: Agemo on 05 February 2013, 20:12:41
You "Bodge" is probably better quality than OE!  :y
Post by: Brikhead on 06 February 2013, 13:59:45
Just need ... the little connector for the washer fluid pipe. The one about half way up, near the suspension strut.
Only pennies from the dealer I'd have thought but I can Post you one out for a Fiver, if needed...
Post by: Brikhead on 06 February 2013, 14:01:22
Only pennies from the dealer I'd have thought but I can Post you one a couple out for a Fiver, if needed...
Post by: Brikhead on 06 February 2013, 14:02:14
Post by: tunnie on 06 February 2013, 15:44:47
Did'nt think to ask dealer, had a feeling they would want to sell the whole pipework...
Post by: TheBoy on 06 February 2013, 19:33:14
Any autoshop.  Maybe not the 'tard in Brakkers, though. Must be plenty in Londonium
Post by: Andy B on 06 February 2013, 20:03:24
http://www.ebay.co.uk/itm/CONNECTOR-FOR-4mm-WINDSCREEN-WASHER-PIPE-TUBE-UNIVERSAL-AG1-/280965719338?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item416adca52a
It'd cost as much in fuel &/or parking charges to actually go out & buy one.  :y
Post by: albitz on 06 February 2013, 20:09:25
I know I dont have a spare one.They break as soon as I look at them. ::)
Post by: tunnie on 06 February 2013, 21:26:02
Most are tube ride away though
Thanks Andy, appreciate it  :y - free delivery too, fuel or tube would cost that alone.
I'm not the only one then  ;D
Post by: Andy B on 06 February 2013, 22:04:22
I learnt that valuable lesson 30yrs or so ago, ie don't try working on anything plastic that goes brittle when cold ...... it'll break! I'd ended up with frozen washer fluid & washer pump on my Manta B & so was trying to speed up the thawing out process  ::) ::). I broke the nipple off the washer pump!  :( Vauxhall wanted what was a fortune for young apprentice so I just glued the pipe to what was left & left it alone. Since then, anything to do with small bore plastic tubing has also included a kettle of hot water to soften it all before hand.  :y :y :y
Post by: tunnie on 09 February 2013, 13:14:56
Right so ordered one now, just got to remove my bodge & feed the tube back to its correct route.
Currently going up the side of the bay near the fuse box  ::)
Might put dab of grease on it to hopefully stop it being such a git next time  :)
Post by: Cliffo B on 09 February 2013, 15:19:16
Tunnie take my word for it forget the grease
Job as simple as pie
Done the job last week when I swapped scuttles
Dunk pipe in a pot of hot water :y :y :y
Post by: tunnie on 09 February 2013, 15:24:28
Cheers, will do, should soften it up  :)
Could have done with a pot of that in a German service area  ::)
Thanks again to AndyB for the link  :y
Post by: Andy B on 10 February 2013, 22:40:45
 :y :y :y :y
Post by: Vamps on 12 February 2013, 00:20:00
A garden centre or tropical fish shop will also supply that fitting, I have all sorts from a micro bore garden watering system, not currently in use....... ::) ::) ::) ;) :-X
Post by: Vamps on 12 February 2013, 00:21:42
Why can I not edit this?
Post by: tunnie on 12 February 2013, 00:49:07
Can't edit in sale section  :y
