Omega Help Area => Omega General Help => Topic started by: kenny71 on 11 February 2013, 18:21:47
Title: 98 Catera wont start after driving
Post by: kenny71 on 11 February 2013, 18:21:47
98 Catera wont start after driving.... help  :'( ok car starts in the morning no problem...then i park and cut off engine go back and it wont start ...if i leave it there for say 2-3 hours and if i dont drain the battery from trying to get it started. it starts again with no problem but if i leave it in idle without giving it gas it cuts off again and have to wait  2-3 hours again... why is it doing this???? i have clogged breather which im about to clean saw creamy paste in breather hose and oil cap ....non on dipstick
Title: Re: 98 Catera wont start after driving
Post by: VXL V6 on 11 February 2013, 18:22:50
Check the codes, could be a crank sensor issue.  :y
Post by: symes on 11 February 2013, 18:25:43
remove plenum and use airline to blow crud out of ya breathers-effects ya idle- :y :y If same after that-do ya plugs
Post by: henryd on 11 February 2013, 18:30:42
+1,same symptoms mine had when the crank sensor went,I didn't get a code though ::)
Post by: kenny71 on 11 February 2013, 18:33:49
thanks no codes showing up so far had it at Advance auto yesterday.....would the clogged breather stop it from restarting?? also i was told that if it was a crank sensor it wouldnt start at all...im not sure just dont want to go buying part after part ..thanks again
Post by: henryd on 11 February 2013, 18:37:22
Wouldn't have thought the breathers would stop it running,when my sensor went car would run fine until stopped at a junction or similar and would then cut out and may take 10-20 minutes before it would restart
Post by: The Red Baron on 11 February 2013, 18:37:57
crank sensor doesnt always throw a fault code, can be intermitant also. would be code 19.  :)
Post by: Paddy Flannery on 11 February 2013, 18:41:59
Although my failing crank sensor showed a code, your non starting issue from warm and being able to start from cold are same symptoms my 2.6 had.
Genuine crank sensor cured it.
Post by: cem_devecioglu on 11 February 2013, 19:29:21
+1 crank sensor..  be careful for replacement model..
Post by: ted_one on 11 February 2013, 19:33:12
Had the same last week,crank sensor replaced done 500 miles since.....running as it should :y :y
Post by: dbug on 11 February 2013, 19:48:10
Really need to check codes mate.
However classic signs of failing crank sensor ;)  Only fit genuine GM replacement ;)
