Omega Help Area => Omega Electrical and Audio Help => Topic started by: Jim on 17 February 2013, 01:22:45
I have an Electric Sunblind which I want to fit to my facelift omega, but when I looked behind the trim in the boot the connector plug was different, did they fit different plugs on the facelift to the pre-facelift??
Probably, there are a few plugs around the car that are different :-\ wire coding should be close enough to wire it up ok :y
Yep
Yep
Cheers Pete :y
I take it the wiring is the same, so just cut the old plug off and rewire?
It's only the very late FLs that have the different plug.
Yes, just change plugs/connectors :)
Cheers :y
