Chat Area => Omega Gallery => Topic started by: GmasterT on 24 February 2013, 22:14:10
Title: My all rounder project (thread lifted from none omega site, excuse egg sucks!)
Post by: GmasterT on 24 February 2013, 22:14:10
Thought I'd put some details and pics up of my latest omega, some may be interested, most will be upset its a vauxhall, but it has some bits of mild interest.
The other reason is I have a comlplete lack of ability to finish a project as I generally start with very little parts and even less money :smash: alas, I started this one with many omega parts and no money, so the chances of failure are much less :wack: that and I'm not overly bothered where I go with it so Im not pursuing 1JZ's and V8 DTM specs, just something that ticks many boxes...
Started as 2 and become as one...
A few may remember the old white drift wagon I dragged up to awesomefest, a 3.0 early ex plod motor, previously owned by a few careful owners such as, the met, the met skid pan dept, a man who took it to the 'ring for a laugh, Inital J/Dan Chapman, Me... so it's been a well looked after and understressed car... :wack:
(http://img.photobucket.com/albums/v208/GmasterT/mif2.jpg)
(http://img.photobucket.com/albums/v208/GmasterT/untitled3.jpg)
(Mods at that time, 3.2 headers, lowering springs (estate!), front poly bushes, short ratio welded diff, bucket seat, air filter, cats cut out)
at the time I was breaking a few of these on the side and came across this...
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0447_zps753d8614.png)
Early 3.0 Elite Auto with Irmscher bodykit and wheels, looks like its had a full respray too at some point, tints and posh back box... money to be made when pulled apart... plus I missed out the first time it was on ebay as decided it went for too much... the 'winner' didnt show so I got this second time round...
Alas, I'm a big sack of rwd vauxhall loving shit and decided it was too nice to pull apart (plus the previous owner pleaded I wouldnt!) so I thought I could break even on selling the wheels and back box and keep it.
This obviously meant it needed manualling which would require bits from the white one. I decided best thing to do was pull the engines out of both and put the whole sha-bang into the blue car. Yes the engine had been thrashed, but its proven and pulled well. So at GMasterT Heavy Industries international construction and development centre (a barn I rent) This happened
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0539_zps739c48b6.jpg)
Revealing this...
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0541_zps04b84698.jpg)
While engine was out, new cambelt was fitted (genuine GM, £12 from garage clearance on ebay!), DMF removed and replaced by 2.0 turbo solid unit (C20LET) with vectra cover and spacer on CSC in the box (around a 3rd of the weight), as well as 'G' cams across the board (G are the inlet cams found on the 3.0 and 3.2, now also on the exhaust side and are the most aggresive standard vauxhall cams in the v6. If fitted into a 2.5, around 15-20bhp is often gained!)
New cam cover seals invested in too as they often weep, 8nm is the key there and the most important tourque figure on the engine! :smash: Anyway, I digress, this is getting geeky even for me...
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0485_zps4c25a3ba.jpg)
Engine going in... I was'nt going to mess around with the air-con, but just after It went in, it was really hot :ghey: so I transferred over all the gubbins... whats the point of elite spec insides without the coolness eh?!
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0549_zps1fd78a8f.jpg)
so, the bulk of it in. You can see varying degrees of holes I drilled into the air con fan surrounds to try and help with throughfare, also, the polish red box of pikeyness... the omega as standard has a dual ram inlet thingy that changes the air tract as the revs gain, this is a polish copy of an expensive german tuning part that Serek, the pilish god of Omega's recommended. We tried it on the white car and on the rolling road and the tourque and power curves were beautiful. plus it sharpens up the throttle response so must do something! Also the long pipe with the filter. This drops through a (cut) hole to behind the drivers foglight for cool lovely air... rather than hot engine bay air...
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0552_zps14f50025.jpg)
Once it was up and working, I took a couple of shots...
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0553_zpsf11db0a2.jpg)
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0554_zps6e199e6d.jpg)
Also note the one of the 2 hyabusa cans you can see at the back, bit wonky as still need to sort a nice hanger for them.
Title: Re: My all rounder project (thread lifted from none omega site, excuse egg sucks!)
Post by: GmasterT on 24 February 2013, 22:14:30
After this, I fitted some 2nd hand eibach springs and stole the polybushed arms from the white car. Its first full shakedown was drift taxis at PVS show where it did well, but I was fairly laid back about it all and was checking stuff over quite reguarly. Sadly no pics there but have a few from pod the following weekend...
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0834_zps8e5cdd44.png)
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0836_zpsfdc71815.png)
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0837_zpsab89140c.png)
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0835_zps77c5df2f.png)
(http://img.photobucket.com/albums/v208/GmasterT/IMG_0840_zps2a416d0a.png)
Blonde not included :D
And due to new work commitments, she's laid up and Ive been using my diesel mondeo, but that may all change...
Anyway, I have some carbon (effect :wack: ) Irmscher interior panels to put in and want to swap the cream for black, as well as lose the blue bucket seat and find some black recliner like buckets. I do have a wand to fit and hope to do so by fitting it onto the standard handbrake and hide the hydraulics in the centre console. I also have some facelift (colour coded) door strips to paint and fit which should make a huge difference and also sorting out some mini facelift xenons...
Other than the possibility of trying some coilovers (Apparantly I can mod S13 rears and Golf fronts for ulimate budget spec), sorting the cruise control and air con pipe, Id just like to use her a bit!
Post by: albitz on 24 February 2013, 22:31:40
Good work fella,and if Im not mistaken,those are the elite alloys I sold you a couple of years ago ?  :y
Post by: GmasterT on 24 February 2013, 22:34:15
Quite possibly mate, I have a few sets now lol :D The facelift trims I refer too are the ones from you though  :y
Post by: albitz on 24 February 2013, 22:37:44
Black trims iirc.I actually have a dark blue set here now.Come and swap them if you want. ;D
Post by: GmasterT on 24 February 2013, 22:58:11
Ooooh, if theyre the same colour then I will dig out the black ones  ;D  :y
Post by: albitz on 24 February 2013, 23:10:18
Z20h iirc.Might bea bit darker than your shade of blue. Im not sure tbh.Your welcome to swap them if you want to though. :y
Post by: cem_devecioglu on 25 February 2013, 17:28:21
Good work and thanks for sharing :y
Post by: serek on 25 February 2013, 23:42:28
looking good  :y
Post by: P6UL K on 01 March 2013, 01:24:58
Mr GmasterT I shall need to pick your brains! PM coming your way!!  :y
Post by: GmasterT on 01 March 2013, 20:59:39
looking good  :y
With a big thanks too you mate :) will have to come see you soon!
Post by: serek on 01 March 2013, 22:47:51
looking good  :y
you welcome any time  :y
btw are still have this 4.22 diff?
Post by: plym ian on 02 March 2013, 07:16:28
nice looking motor :y
Post by: GmasterT on 02 March 2013, 07:30:09
looking good  :y
Of course my friend, I'm a looking after it for you :D
Post by: Steve B on 02 March 2013, 21:26:04
lots of work been done there  :y
Post by: GmasterT on 05 April 2013, 23:10:14
Essential drift car modifications... ICE lol
Basically, Ive found some stereo bits and the farmer I rent my barn from was having a clear out and oddly found a sub and amp he gave to me :D So Im getting ICED up yo! But I also want to change the doorcards to black and wood to carbon (have the Irmscher panels)... I think Im just making the Omega I wish I had when I was 21...
(http://img.photobucket.com/albums/v208/GmasterT/26A70D27-52AC-4BB5-9A1D-AA817FAE0CDB-912-00000194D9D23E72_zps1bebea00.jpg)
oh, and nokia bluetooth through the stereo I found in one of my breakers... posh vauxhall drift car... does not compute!!
