Omega Help Area => Omega Electrical and Audio Help => Topic started by: amba on 27 February 2013, 20:18:55
Title: Fuel pump/injector relays
Post by: amba on 27 February 2013, 20:18:55
Have got a intermittant starting problem which  I seem to have traced back to the relay inside the engine bay compartment.
There is 2 mauve relays which seem to control the fuel pump and the injectors and advise seems to suggest it would be wise and probably as easy just to replace the 2 and be done with it .
Are these a main dealer part...? and if so has anybody got access to the GM part numbers or can these be sourced elsewhere.
Dont think it would be wise going down the second hand route but eill accept any advise please  :y
Title: Re: Fuel pump/injector relays
Post by: kenny71 on 27 February 2013, 20:28:16
they should be easy to get..just got 2 the other day from auto store paid 10 dollars for each
Post by: amba on 27 February 2013, 20:29:42
That is on your side of the "pond"..though ;D
Post by: I_want_an_Omega on 28 February 2013, 09:56:50
Hi Andrew,
I'm fairly certain that I have a complete spare V6 fuse box rescued from a '98 car before I scrapped it. You are welcome to those relays for the price of the postage if that helps?
Let me know & I'll have a rummage in the garage ......
Rob
Post by: Elite Pete on 28 February 2013, 10:15:11
And if Rob hasn't got them I know I have :y
Post by: amba on 28 February 2013, 11:14:51
Many thanks for offer of help...Rob @ Pete. :y :y :y
Think I am sorted now as needed to get them sourced today as didn,t want to risk breaking down again today,so found local breaker which I have got them from so fingers crossed they are the problem.
Not sure how likely my problem is to be the relays or the actual pump...car wouldnt start on several occasions recently but after wiggling the violet coloured relays  in the relay box ,it fired into life so am thinking 1 of them is probably sticking or just "tired" and as they are the easiest parts to replace first that will be my plan.
Post by: symes on 28 February 2013, 20:35:34
chech your loom plugs by battery mate they can cause your problem-in fact on my miggy it even bought up Gearbox Fault on MID :o and also when engine running you could move one loom connector and stop engine :o opened them up and closed up terminal connectors on female end and job done :y
Post by: amba on 28 February 2013, 20:40:10
Thanks for "heads-up".
I will have a good look in the morning when I replace the 2 relays. :y
Post by: amba on 04 March 2013, 16:58:04
Sorry to drag this back up but just need a bit more info.
Replaced both relays and car started and ran fine for couple of days  :y then started playing up again  :'( ,but managed to get it to fire into life by "thumping" the underside of the fuel tank. ;D
As it now seemed to point conclusively to the pump I  have replaced it with another.
What I would appreciate is some advise as to how reliable are these electric fuel pumps and has anybody else had issues with the fuel pump.
Post by: Nick W on 04 March 2013, 17:18:29
The pump runs all the time the engine is. It's a small electric motor, pumping fuel at over 3bar.
These cars are now at the age when having to change a fuel pump should be considered a perfectly reasonable expectation. Fit a new one, otherwise you're just shifting the problem into the future.
Post by: amba on 04 March 2013, 17:36:21
Wise words,Nick. :y
Thanks  :y
Post by: I_want_an_Omega on 04 March 2013, 19:09:40
+1
Unless of course you can get one from a low miles breaker
Post by: Lazydocker on 05 March 2013, 07:59:06
I assume you've read the codes and there isn't a Crank Sensor code? ???
Sa for the in tank pump... I thought they were very reliable but it could be the fault. I'd be looking very carefully before spending money though as you've now doing 2 different "cures" for the fault ;) (Which, incidentally, is a classic symptom of Crankshaft Sensor Failing ;))
Post by: amba on 05 March 2013, 08:36:29
LD...no fuel was present when I removed the fuel pipes from the engine when cranking over.
Car started on several occasions when the relays were pushed/pulled around but despite them being replaced with new problem was still there.
Fuel pump has now been replaced and car started.No fault codes are present,although slightly worrying is when I connected the old pump up to 12v it ran but I am suspecting it was getting a tad "lazy" and would stick.
Thanks for all the usefull info guys and I hope the problem is now cured. :y
Post by: 05omegav6 on 05 March 2013, 12:08:30
My pump failed about 2k after the crank sensor ::)
I think this was because I had been trying to churn the engine over alot for about two weeks prior to sorting the crank sensor, and had also managed to run it dry a couple or four times  :-[
Current pump, a pattern one has been in for 110k, original managed about 125k :y
Post by: Lazydocker on 05 March 2013, 12:15:49
Fuel pump doesn't run without a signal from crank sensor ;)
Perhaps you have found the fault but the fact the old pump still runs fine makes me think you should be carrying a spare crank sensor ;)
