Omega Help Area => Omega General Help => Topic started by: whamalek on 04 March 2013, 07:50:46
Title: Omega 2003 2.2 Automatic GearBox Problem
Post by: whamalek on 04 March 2013, 07:50:46
Dear All,
This is my first post in this great forums...
I have a problem, and no mechanic was able to solve it since around one year...
I have a 2.2 2003 Opel Omega, Automatic GearBox, I started to get a weird behavior from the gearbox , Sometimes during the day, when i start the car,  the engine sounds very weird, and if I put the gear selector to (D) to start driving, the car switch directly to gear 4 ! and doesn't start from the first gear! I have to manually select gear 1 and the car will start moving with a very very bad smell coming from the engine. than when i reach speed of around 60 I have to switch to gear 2 manually, the car will switch but the a very loud bang into the gear box, and it will switch to gear 4 not 2!
If I continue like this, the car will heat up !!!
Sometimes, I see all gear selector lights goes on at once!
In this situation, I can't turn the Sport mode on or the Winter mode on.
If I turn the car off, than on again, like 3 , 4 times, it works! like nothing is there! and then i can drive it perfectly, then If I stop and turn the engine off, go for an hour come back, it will do it again.
Any help is really appreciated.
Title: Re: Omega 2003 2.2 Automatic GearBox Problem
Post by: steve6367 on 04 March 2013, 07:58:19
There is a maintenance guide for cleaning the gear selection switch, which would help with the Christmas Tree of lights.
I suspect it would be good to get the codes read too if you can.
Steve
Post by: whamalek on 04 March 2013, 08:52:10
Thanks for the reply.
I went to the mechanic, he told me after he checked that it is GearBox Computer Scensors...
We change it, nothing happened! then, he told me it is the GearBox computer, I changed it, and no luck too!
The Fault code remains to say Gerabox computer fault, now, since around 2 months, the fault code is gone! I don't even have a warning on my dash board.
Post by: steve6367 on 04 March 2013, 09:42:02
Can you give this a go?
http://www.omegaowners.com/forum/index.php?topic=90673.0
Steve
Post by: whamalek on 04 March 2013, 10:33:46
I'm desperate  :'(
I can try anything...
Can you please tell me where exactly I'll find this part?
Post by: steve6367 on 04 March 2013, 10:56:05
It is under the car on the side of the gearbox
