Chat Area => General Car Chat => Topic started by: I_want_an_Omega on 08 March 2013, 18:56:57
Title: Oil quality monitor ........
Post by: I_want_an_Omega on 08 March 2013, 18:56:57
My Mk4 Mondeo is fitted with an oil quality monitor which will prompt for an early oil service if needed. I hope to never see it come on as I am changing the oil every 3,000 miles anyway.
My question is how exactly do these work? Is it a chage of an optical characteristic perhaps?
Title: Re: Oil quality monitor ........
Post by: danzigfan on 08 March 2013, 19:34:07
AFAIK this systems only calculate when the next oil change should be - depending on driving style...etc....
My opinion...you 'll get less than expected out of your car if relaying on that sensor. And that's the main purpose of this sensors
Post by: I_want_an_Omega on 08 March 2013, 20:19:18
I am sorry - but I think you are wrong.  :-X
Post by: danzigfan on 08 March 2013, 20:35:57
Maybe on some Merc you'll get sensor which electricaly tests conductivity of oil inside the sump but definately not in Ford or GM
Post by: scottambrose on 08 March 2013, 20:37:19
Loads of audis chave had these for a while if you put the wrong oil in or it gets allmanky it wans you and puts it in limp mode
Post by: I_want_an_Omega on 08 March 2013, 20:41:38
why not ?
Post by: scottambrose on 08 March 2013, 20:49:15
Fords are quite complex nowadays they use low saps oil and i wouldnt be surprised if it did have sensors. Longlife oil was designed designed to work with how you drive. I get asked how ling does longlife oil last? It could20k it could be 3k depending how you drive and what journeys you do
Post by: Marks DTM Calib on 09 March 2013, 06:20:35
They only have a pressure sensor, the oil life is calculated based on pressure and useage
