Omega Help Area => Omega General Help => Topic started by: sjc on 16 March 2013, 12:56:35
Title: What is different between manual and auto throttle cable?
Post by: sjc on 16 March 2013, 12:56:35
Anyone know what is different between these?
 90571262  8 47 153 CABLE, ASSY., ACCELERATOR (IDENT JY) (USED WITH MANUAL TRANSMISSION)
 90571263  8 47 154 CABLE, ASSY., ACCELERATOR (IDENT JZ) (USED WITH AUTOMATIC TRANSMISSION)
Title: Re: What is different between manual and auto throttle cable?
Post by: serek on 16 March 2013, 16:07:25
Length  :y as manual need different route
never replace cable when converting car from auto to manual
Post by: sjc on 16 March 2013, 16:12:29
Cheers Serek.  Trouble is I need to replace it because the cup/ball at the throttle end has been mashed by a previous owner/garage not knowing how to remove and you can't get retaining pin in or out - it's currently bodged to keep it on!
So I was wondering (as you rightly remember I'm going to ditch the slush-box) if it was better to get the manual cable.
BTW, how's your Gloabl TIS working?
Post by: I_want_an_Omega on 16 March 2013, 17:29:35
Auto also has kick down switch doesn't it?
Post by: Andy B on 16 March 2013, 21:20:57
I'd say that was the main reason  :y ..... and why would the manual vs auto need a different route?  :-\ :-\
Post by: 2woody on 17 March 2013, 14:21:38
same length.
Auto cable has kickdown switch. Not requiredd if you've ditched the fun-free transmission
Post by: sjc on 29 March 2013, 19:47:25
So either will work for manual albeit perhaps with an extra bit I don't technically require.
Cheers for replies  ;)
Post by: 2woody on 30 March 2013, 22:18:29
you might just feel the the detent for kickdown at full throttle
Post by: feeutfo on 31 March 2013, 09:43:28
same length.
In favour of the Victorian signal box with block and tackle clutch operation..? ;)
Post by: 05omegav6 on 31 March 2013, 10:04:01
You just jealous because your car doesn't work in snow :P
Post by: Lazydocker on 31 March 2013, 10:22:18
Mine does
Post by: TheBoy on 31 March 2013, 11:01:40
Mine does
As does mine. And I can show it corners wet or dry...
