Omega Help Area => Omega General Help => Topic started by: raywilb on 17 March 2013, 10:43:48
a while back I posted about a noise when turning left. I finally found out that a broken spring & also a wishbone rubber has play. the mechanics side of things I can fix but the camber set up I,m not so sure about. I don't know if there is a place near York that provides the service w.i.m does . plenty do a 4 wheel alignment but its not the same ,is it? :-\
Nigel Langs in Bolton seems to be the preferred choice oop north.
http://www.nigellangsgarage.co.uk/page/Wheel-Alignment/
I,ll probably try to get over there . its camping out on the m62 I dread.
Nigel Langs gets a thumbs up from lots on here, I'm a bit further south and use Fleet Fit in Loughborough but I think that's a little far for you!
