Chat Area => General Discussion Area => Topic started by: Nickbat on 27 March 2013, 18:57:01
I have an outside tap with threaded end.
I want to fit a shower hose on it, but can't find what sort of adaptor/connector I need. Any ideas? ???
(In case anyone is wondering, the tap feed water from a regulator valve inside the house, so I can shower the dog with pre-set tepid/warmish water after his daily walk) ;)
Do what I did, Nick. Buy one of those cheap shower thingies that fit over the bath taps, then take the shower head off it an attach a garden hose which you can buy a tap connector for.
Actually, I did it slightly different. I took both end of the plastic tubing and fitted them to a garden hose. Now I attach it to the kitchen tsps and take the shower head outside.
http://www.amazon.co.uk/Hairdressers-Single-Shampoo-Hose-Attachment/dp/B002SA0OJW/ref=sr_1_2?ie=UTF8&qid=1364412740&sr=8-2
This one's a bit dear, but I reckon that shower head would go on a garden hose.
Nick would probably prefer to do a proper job. ::) ::) :P
That is a proper job and, the part that should appeal to you, tight arse, it's cheap. :y
Yep. ;D ;D. I've always been just one step away from destitution. :'(
I wish I had your wealth. :-\ :-\ ;)
Have you considered employment.....for Mrs Opti, of course.
Do you mean work for a living?....How very dare you. ;D ;D ;)
Sorry. I shouldn't have mentioned it. :-[
Or you could go this way:
http://www.amazon.co.uk/s/?ie=UTF8&keywords=hosepipe+tap+connector&tag=googhydr-21&index=aps&hvadid=14185927808&hvpos=1t1&hvexid=&hvnetw=g&hvrand=166301003549945613&hvpone=&hvptwo=&hvqmt=b&ref=pd_sl_d8bpcxhch_b
I think it is cruel to even think about showering a poor dog in this weather outside.do it indoors.there are plenty of ways :y
(https://dl.dropbox.com/u/70807181/dogbog.jpg)
I was hoping to use the shower tubing I already have, but maybe I need to go down your route, Steve.
Thanks. :y
;D
I'm sure a couple of plumbing fittings would do the job. I'll have a rummage in my plumbing box and see if I can figure it out.
