Omega Help Area => Omega General Help => Topic started by: Ralph on 29 March 2013, 10:40:00
I've got a fairly bad front O/S suspension rattle which has got worse recently.
The drop link has been replaced so I guess bottom arm is the culprit.
What is the going rate for replacing these, it's not a job I'm equipped to tackle ?
Any advice appreciated.
2woody is up your way i think. Drop him a pm. I'd suggest diagnosing the exact fault before going any further.
When was the droplink replaced, and with what :-\ Cheapy ones can fail much more quickly than they've any right to :'(
as already stated by chris there's a lot of parts related to the front suspension of a mig, so really need to identify the affending item rather than changing parts on a wim hth ;)
Drop link was replaced 3 weeks ago.
The bushes on the Arm look tired especially the rear one.
Are you sure the drop link nuts are tight? I had a similar fault, turned out to be drop link nut not tight, so drop link top eye moving up and down on nut.
Check for a broken spring :y
Cause found today, knackered steering tie rod, previously replaced 2 years ago.
Rubbish pattern parts it would seem.
Been there myself. Tend to stick to GM parts for track rod ends now.
