Omega Help Area => Omega General Help => Topic started by: olzz on 30 March 2013, 15:24:08
Title: Shock absorber test?
Post by: olzz on 30 March 2013, 15:24:08
Hi,
Im driving with Omega Estate 2,2 gasoline,since 2001.  Rough winter has done negative effect for the car suspension- rear shock absorbers feel too soft.
I have one set of rear absorbers from 2,2 bensin donor Omega. Does anybody have a instruction, how to test absorbers good fit before fitting?
There is no oil leakage noted about the replacement ones.
Cheers,
Olari
Title: Re: Shock absorber test?
Post by: kevinp58 on 30 March 2013, 15:26:49
Push them in and if resistance is felt pulling out then should be ok the more resistance the better.  ;)
should be a smooth action too.  :y
Post by: feeutfo on 30 March 2013, 15:42:05
Should be controlled damping on compression and rebound stroke. No tight or loose spots.
When released from full compression they should return to full extension on their own in a slow controlled manor.
No oil leaks obviously.
