Omega Help Area => Omega General Help => Topic started by: Selseybill on 04 April 2013, 13:09:56
Title: Thermostat housing bolts
Post by: Selseybill on 04 April 2013, 13:09:56
Any one know the part number for the 2 x torx bolts on the Thermostat housing on a 2001, 2.2 petrol
Title: Re: Thermostat housing bolts
Post by: Selseybill on 09 April 2013, 14:47:20
Anyone help. Vx dealer thick as sh** or can't be bothered.
Post by: Entwood on 09 April 2013, 16:28:40
Be careful .. the thermostat design changed and the flange got smaller, so new shorter bolts needed with the new housing .. if you use the original bolts they "bottom" and will either not tighten or crack the head - depending how much OOMPH you apply ... :(
PM to AndyC might be the safest way ...
(all the above applies to the 3.2 ... perhaps the 2.2 is different ??  )
Post by: Webby the Bear on 09 April 2013, 16:55:27
I swear on my life someone posted pretty much the same question about a week ago and AndyC came on and confirmed exactly what you say Entwood...... gone back but can't find the thread  :'(
Post by: Kevin Wood on 09 April 2013, 17:02:46
Yep, got my set from AndyC and he very helpfully included all variants of the bits and pieces so I wouldn't be stuck. :y
IIRC there are a couple of variations of the O ring that seals the thermostat housing to the block too.
But.. if the one you're being supplied with has the thinner housing, the worst case is that you need to shorten the bolts a little.. assuming it comes with the correct O ring.
Post by: amba on 09 April 2013, 17:11:14
When I replaced my stat last year I was supplied with exact same thickness housing as I had removed.
The black "0" ring did look slightly odd and hardly seemed to compress into the recees on the housing when tried so I ran a small bead of oil cooler sealant around the edge to be sure of a good tight seal.
20k later and not a sign of any leaks so as its a job you don,t want to do twice that would be my best advise.
Post by: Selseybill on 10 April 2013, 10:34:10
Cheers lads. When trying to undo the torx bolts the head on one just rounded off. The Vx dealer is no help at all. Tried last week to use the master fit club voucher last week but the 2 Vx dealers told me i can only use it for servicing. Even showing them the letter they told me it's for servicing only not parts.
Post by: 05omegav6 on 10 April 2013, 12:37:04
Frosts :-X
Any reason not to reuse the bolts?
I appreciate that you have a rounded off one, but asking for future reference  :y
Post by: Selseybill on 12 April 2013, 12:29:20
Frosts :-X
Say no more
Post by: biggriffin on 12 April 2013, 18:02:02
i think they are m6x20 the short ones and m6x30 the long ones. any fastner supply about 20p each and some washers.or even halfords.
Post by: Selseybill on 13 April 2013, 16:59:01
Cheers Biggriffin. Now i know the size
Post by: Andy B on 13 April 2013, 18:28:46
I'll bring you a hand full of stainless bolts in the summer ......  ;) ;)
Post by: Selseybill on 13 April 2013, 21:01:36
No Probs. Am off back home next month where the sun should be.
Post by: Andy B on 13 April 2013, 21:03:39
We're staying at La Garangeorie for the last fortnight of June  :y :y
Post by: Selseybill on 13 April 2013, 21:14:24
Not a million miles away. Just north of us
Post by: Andy B on 13 April 2013, 21:20:32
I seem to remember you saying it wasn't far from you  :y
Post by: biggriffin on 13 April 2013, 22:38:32
stainless nuts n bolts are cheap as chips,best place is grampian fastners in aberdeen or any were there is a large off shore industry,as they use stanless nuts n bolts on every thing..
Post by: Andy B on 14 April 2013, 00:21:08
Even cheaper from stores at work .......  ;) ;) ;)
