Chat Area => General Car Chat => Topic started by: omegod on 13 April 2013, 12:43:08
Just spotted a really clean gold 53 reg 2.6 CDX with 105k on it, reportedly brought in with a misfire but on closer inspection looks to have oil pissing out of the back of the engine which looks to be more than the rocker covers it obviously needs, they want £350 for it..Hmmmmm it does look minty nice :-\
Any thoughts on what the leak may be?
Oil cooler/dowty washers perhaps
Bad rocker gasket or oil cooler/feed lines/washers as said above.
Go for it, lots of help on here :y
I have never seen a rocker cover cause the oil to drip out the back at this rate , literally dripping like a tap
Will do if half moon at back not seated properly ;)
Mine was pissing out when my halfmoon didnt seal
Thing is, apart from the oil cooler pipes, as already suggested, there's very little else it could be. Given the misfire too, I'd say cam cover gaskets.
Can't see it being anything major.
Do it!
No chance of it being a crank seal?
Even if it was a breaker....£350?
Knobheads have lost the key ::)
It'll be even cheaper now then :y
Lol Pete, it has tax and MOT too :y will definately be having it if they find the bloody key
Ask them to reduce the price and then buy a barrel, key, chip, pick up and ECU off a breaker ;)
Oh and you'd better be quick, i'm looking through the scally pages as we speak ;D
Key found. Runs like shit and is showing codes for misfires on both banks, taxed till the end of May, MOT until November, recent crank sensor fitted, getting delivered tomorrow :) :)
Cheap enough nonetheless, good buy if you ask me :y.
Keep your eye on eBay. That scally will have it up as a minter.
Your right, I would have any munter......sorry misread that Ste.
New plugs and cam cover gaskets and job done hopefully but may need coil pack too. Result :y
Don't forget to check to boot for a dead body ::)
Well it's here, top end stripped within half hour along with the obligatory cut's to my hands. Drivers side coil pack bathed in oil and cracked, drivers side dry as a bone but original coil pack a bit manky so will need cheap/used replacements. Gaskets on order!!
2.6 is a much tidier engine bay than a 3.0 :y
Just the cover leaking oil then :y
Jammy bastard....just like Everton.
Get plenty of "2.6" practice. Put you in good form for mine :y :y :y
Does it need an oil cooler :-\
Not from what I can see so far
I had an oil spill in the same location as the one you mention plus bad misfire and management light flicking on and off. Still made it back from Glasgow to Northampton though. Fault-coded it and it listed a misfire in the RH bank. Turned out to be the rocker gasket breaking down and letting oil fill the plug recesses plus letting oil flood down the gearbox and exhaust from that half-moon shaped bit. Hot oil cooked the coil pack which cracked and was full of oil. I got a dis pack for £70 from VauxhalWorldParts.com (half price effectively, and it arrived next day). That's for the v-6. Not tooooo bad a job if you have all day!! I managed to do it without removing the fuel lines from the intake but is was a very tight squeeze to get the cover back in without dropping the rubbery bits. Oh, and I've got three hands.
Seems to be the same scenario with this one with the driver side leaking, will try and clean up the CP's but got some known good ones on the way from an OOF member just in case. I'm well versed in stripping the top end off after doing the exhaust manifolds on my last Mig so find it easier to gat all the crap out of the way and it's then easier to get to the breathers too. Fingers crossed it pans out smoothly.
